Results 1 to 3 of 3
Thread: m4-atx power on pulse
    Feb 2008
    I can't get my m4 to send a power on pulse to the motherboard. It works just fine if i short the two pins off the motherboard, and it also powers down just like it is supposed to. Anyone have any suggestions that doesn't involve throwing the m4 in the trash? Also I read in a post on this forum (don't remember which one) Where somebody had a problem with the accessory trace and fixed it. What does that mean? They had the same problem as I did.
    Variable Bitrate bemenaker's Avatar
    Nov 2008
    Did you try reversing the two wires going from the M4 to the mobo? Having them backwards is supposed to make it not work.
    How do you have the dip switches set?
    Feb 2008
    I didn't realize ther was a polarity I though it was just a switch that shorted the two points, but i'm sure I have switched them up because i've disconnected and reconnected them 50 times without regard to which way I was hooking them up. Normally I've had it in p1 mode but I've tried every combination.
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. miniITX power supply for ATX motherboard?
    By uldics in forum Power Supplies
    Last Post: 09-26-2007, 01:17 PM
  3. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  4. POWMAX Mini ATX power supply - Power on leads?
    By e30_droptop in forum Power Supplies
    Last Post: 10-18-2005, 09:50 PM
  5. atx POWER SUPPLY?
    By nickweb in forum Newbie
    Last Post: 09-26-2005, 05:39 AM
