Results 1 to 7 of 7
Thread: Stud Size of M4-ATX
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Stud Size of M4-ATX
    Because I'm using my own case for my project, I want to fabricate a nice connector like that on the back of the Voom2.
    Here's what I'm thinking:
    - 8 gauge from the battery to the distribution block.
    - 16 gauge from the distribution block to the male "mini-fit JR".
    - 16 gauge from the female "mini-fit JR" to the spade connectors on the M4-ATX.
    - Spade connectors into the studs on the M4-ATX.
    So, couple questions.
    1. Does anyone know the stud size on the M4-ATX?
    2. I'm planning 8AWG wire to a distro block, can I run 16AWG from distro to the M4? This run won't be very long, maybe a foot.
    3. Looking at the catalog I have a couple options, Snap Spade, Flanged Spade, Spade Tongue. I'm leaning towards Snap Spade, it looks like it should fit - again though the stud size is going to kick in. Any feedback on which type of Spade?
    I figured this was the best area to post this question. I searched both with Google and the MP3Car search, but couldn't find an answer.
    Thanks for any help anyone can provide!
    Elsewhere
    I wouldn't use 16awg. I'd use 8-10awg from the distro block to the devices and 0-4awg from the battery to your distro block.
    It might be more than necessary, but you'll also know that your wires aren't going to get warm from resistance and you can add more devices later on because you ran suitable wiring in the first place.
    How about the Wiki?
    Jan 2009
    Iowa
    Quote Originally Posted by DarquePervert View Post
    I can do that. Darque do you happen to know the stud size of the M4? I don't have mine ordered yet else I'd take it to the local autozone and mess with spades 'til I found the right one.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    The connector size you need is .250 X .032
    These are what I used. Get whatever size wire you need for them. This is for 16-18ga I think. That is what I have inside my case to the external connector where I step up to 10ga and then to junction block.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Jan 2009
    Iowa
    Okay so I'm revising my thoughts on wiring then. Which I have no problems revising, I'd rather, as Darque stated - be on the safe side with this stuff.
    - 4gauge from battery to the distro (step up fuse size from 50amp to 125amp)
    - 8gauge from the distro to the external connector on the Thin Client
    - 16gauge inside the Thin Client, from the connector to the M4.
    I'll go for the connector fixer has listed.
    I'm assuming then fixer that you've not had any problems with it coming loose at all from your M4-ATX?
    May 2005
    Lawrenceville GA
    Quote Originally Posted by jpinkerton View Post
    No problems at all.
    Jan 2009
    Iowa
    Awesome, I've read the horror stories about the M4, but am looking forward to my purchase. I'll order the parts Monday or Tuesday when I'm back in town.
    Thanks guys for your knowledge.
  1. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  2. fs: mastero mk-3.5 120w atx dc-dc power supply
    By infinkc in forum Classified Archive
    Last Post: 05-16-2004, 07:06 PM
  3. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 01:36 PM
  4. Presario AT or ATX?
    By ppgt94 in forum Power Supplies
    Last Post: 04-11-2002, 05:45 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
