For what it's worth I am running the newest firmware on my M4, which was shipped that way from mp3car.com. I waited a year before purchasing mine so thay could work the bugs out.
I also only use the M4 as a power supply / regulator, I DO NOT use the startup & shutdown controller, nor do I use the amp turn on. I do use the usb monitor feature.
Again I conclude most problems come from improper wiring or general instability on the on/off controller and amp turn on circuits, which, when running an embedded OS , are a joke anyway. My M4 on/off and amp controller circuits are still virgin, and they always will be. I gave up on those types of circuits long ago, pretty much since the main stream production of solid state storage and embedded operating systems. Perhaps my M4 success can be attributed to my usage.
Oh yes, for those that don't bother studying the M4 PCB before installing here is some helpful info:
These corners are primary input positive circuit conductors. In other words, don't use conductive metal standoff's for install, or you can short the IC against ground resulting in sudden death.
http://www.mp3car.com/vbulletin/atta...4-atx-1-lg.jpg
