Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: Is it safe to buy a M4-ATX yet?
  1. #21
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Just checked my invoice, I ordered mine March 29, 2009
    Weird because mine looks just like that.
  2. #22
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Quote Originally Posted by blk02si View Post
    I got my m4 last june and its the same as yours,not used it yet.
    Its finally going into service tomorrow to power my new build in time for the digital car gathering next weekend,it better work as there's no time to order a replacement.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  3. #23
    Jul 2005
    Motorcity
    Blog Entries
    1
    I would hook up the ATX power and P4 power, run it in dumb mode for initinal boot. After it's up and stable, OS installed and it has had some burn in, then proceed to hook up the startup and shutdown controller. I would not recommend hooking up every single header possible and then juicing it all at once. Make sure the power circuits are stable before introducing the others. Is there a logic flowchart available for the M4?
  4. #24
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    I had to return my to MP3car. It never worked right. I'm sorry but if something doesn't work out of the box these days I won't recommend it.. Bought an opus and never looked back.
  5. #25
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I found a website with a photo that looks like, or similar to, the M4-ATX
    version I have.
    Ituner M4-ATX
    So far its the only picture ?
    The Ituner name is also found on mini-box.com, must be the same company
    or something.
  6. #26
    Jul 2005
    Motorcity
    Blog Entries
    1
    Looks like that version also has smaller input capacitors too. Look at C62, C63 and the 3 capacitors clustered right around the input, they are about half the height of the same capacitors on the other board.
    A smaller cap is going to mean less input filtering.
  7. #27
    FLAC WuNgUn's Avatar
    Sep 2007
    So it looks like Minibox must of finally sold their inventory of defective M4's, and now their offering something that actually works...lol
  8. #28
    Nov 2008
    There seems to be a lot more negative comments about the M4 compared to the positive ones. I was hoping for an extra 30 watt because my system is pushing a little over 200 watts at its peak power. I would also save a little bit of money but I have had experience with DSATX so I guess I'll stick with it because I've known it to be a good brand.
  9. #29
    Jan 2008
    Quote Originally Posted by shatteredzman View Post
    While I believe that blk02si is partially right about some problems being user error, I think that it is odd that there are so many negative reviews that after they switch over to a opus, or dsatx, suddenly has no problems at all.
    It is esspecially odd if there was a user error in the hookup, b/c i would think that they would use the same method to hook up their new ps-- they would then have the same problem as they did w/ the m-4...
    has anyone else noticed that the 'm' series have more problems postings than opus or dsatx? it's hard to believe that all of these are user error.
  10. #30
    Maximum Bitrate jpinkerton's Avatar
    Jan 2009
    Iowa
    Most people post when something doesn't work, not when it does.
    I wasn't going to spend a couple hundred on my first DC power supply, maybe in the next vehicle I'll invest in a beefier - OPUS power supply, but for my first run I wanted affordable as the primary objective. I'm assuming most others think the same way.
    With these two thoughts in mind, no wonder more people post about the M4 than the OPUS.
  1. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  2. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  3. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
