Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: Is it safe to buy a M4-ATX yet?
  1. #31
    FLAC WuNgUn's Avatar
    Sep 2007
    I had no problem getting my PC to POST with the M4...
    It just had no audio!!!
  2. #32
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Just powered mine up for the 1st time earlier today.
    It went well i think but i was only using it in dumb mode.
    Amp circuit seems to work,same as the M2 in that respect.
    My pci sound card worked fine and there was no noise at all,i had noise with the M2.
    More testing tomorrow as it all goes together.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  3. #33
    Sep 2007
    May the force be with you...
  4. #34
    Jun 2009
    I have just finished building my car pc. I am using M4-ATX power supply bought last month from cartft.com, so far i have tried the system at home using a power supply and a switch to simulate the ignition switch.
    So far it is functioning very well, even the usb interface. I only tried tempering with the delay time to power on the PSU.
  5. #35
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    ^ Looks like another successful build atop insulated standoff's.
  6. #36
    Sep 2007
    Nice and compact...I like!
  7. #37
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Realy nice buildt case there...
  8. #38
    Nov 2008
    I am going to go ahead and get the M4-ATX. I ran into a financial problem earlier and put my carpc on hold for a while and never bought a power supply. Then I got preoccupied with another project so I will try the M4-ATX and report back how it works out for me.
  9. #39
    Nov 2005
    Midlands
    Quote Originally Posted by Griff1 View Post
    My intelligent M4 was a retard!
    The shutdown controller didn't know what it was doing, the switches had no impact on the shutdown time and it would crash quite often.
    A friend of mine came round and flashed the 1.3 firmware to it and i havn't had a single problem with it since.
    Griff.
  10. #40
    Nov 2008
    I got my M4 and it seems to work fine. I mounted it on insulated stand offs and I have it set to turn the computer on and off. I havnt fully tested the computer to make sure everything is working fine because it is getting late but I will get a picture of it and post it in the other major M4 thread soon.
    *EDIT*
    I have tested all of the M4 functions and everything works, not one single problem.
  1. Replies: 13
    Last Post: 07-19-2007, 02:57 PM
  2. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  3. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
