Results 1 to 9 of 9
Thread: M4-ATX Power Switch Problems!
    May 2009
    I have a M4-ATX that i just hooked up and i cannot get it to power the computer on. I have tried all different dip switch settings and my last test i set all dip switches to OFF and and connected an external power switch. This even didnt get the computer to power on. Any advice?
    Mike
    Also if someone could explain the dip switch settings that would be great because the manual is not very clear.
    May 2009
    Quote Originally Posted by Enforcer View Post
    Make sure the lead to the motherboard header to do the power is the right way round
    I connected a separate power switch and it still didn't work.....
    Thanks again for your help.
    Mike
    Elsewhere
    I'm pretty certain the DIP switch settings and functionality is outlined in the manual.
    Either way, you haven't given us any information that is ueful in troubleshooting your problem.
    How is it wired to the vehicle's electrical system?
    Have you verified the voltages on the power & ignition line with a multimeter? With the ignition off and with the ignition on?
    Do you have all the power-related motherboard connections, including the 4-pin 12v power connector plugged in securely?
    Does the PC boot up if you use an ATX power supply from a desktop computer inside your home?
    Help us help you.
    How about the Wiki?
    May 2009
    Quote Originally Posted by DarquePervert View Post
    Help us help you.
    Im sorry for the lack of information. I have tested everything with the multimeter and i get perfect voltage on the vcc and ground....When i turn the car on i get 12v on the ignition. So that part is fine. The connections on the mobo are also good and the computer does work with an atx PSU. The manual is not clear on the dip switches... There are 4 on the board and the manual covers 1-3 but then it says p1,p2,p3 etc. Also, a light is blinking on the board two fast lights randomly.
    Thanks For all of your help
    Mike
    <Don't post your phone number on an open forum>
    Feel free to PM me!
    Apr 2009
    Newark, New Jersey, United States
    any update to this?
    i am in the very same situation.
    i put in a request to get an rma.
    Elsewhere
    Quote Originally Posted by mk9027866 View Post
    Mike
    Feel free to PM me!
    Quote Originally Posted by trinybwoy View Post
    any update to this?
    Did either of you fire up the PC inside your house/apartment/workplace/laboratory to make sure that all the PC components are in working order?
    Also - trinybwoy You need to do the same as was suggested to the OP. Provide some information (preferably in your own thread to avoid confusion) and include your system specs, how everything is wired up.
    Yes, it's possible that both of you have a dead M4. I personally believe the M4 as a product is a lemon, as there are a lot of owners with problems.
    Shoot, I think all of mini-box's products are lemons because of various problems, design flaws, and failures that shouldn't happen.
    But when you're troubleshooting something like this, there are many potential points of failure. In order to track down the source of your problem, we need to know about all those potential points of failure.
    Is it your wiring?
    Is it your battery?
    Is it the power-button turn on lead?
    Is it PC hardware failure?
    Does the PC draw too much power for the PSU?
    Lastly, have either of you attempted to contact the vendor of your M4 for some assistance? I know trinybwoy requested an RMA, but what about troubleshooting with the vendor?
    How about the Wiki?
    Apr 2009
    hey darquepervert when you vendor, should i contact the maker of PSU or mp3car, who i bought it from?
    in simple terms, Vendor-someone who sells, lol
    Elsewhere
    The vendor is who you purchased the product from.
    How about the Wiki?
  1. M4 ATX Turn On Problem
    By Fox_Mulder in forum Power Supplies
    Last Post: 12-31-2008, 07:43 AM
  2. M1-ATX power switch not working
    By froop in forum Power Supplies
    Last Post: 09-23-2006, 02:30 AM
  3. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  4. Need help with X31 port replicator power switch
    By viguera in forum General Hardware Discussion
    Last Post: 06-22-2005, 11:12 AM
  5. Power (switch) terminals on Mini ATX board
    By muldrick in forum General Hardware Discussion
    Last Post: 08-31-2004, 01:48 AM
