Results 1 to 4 of 4
Thread: Strange M4-ATX problem with Stranger Resolution
    Low Bitrate RonsRed88's Avatar
    Aug 2009
    Western Washington State
    Here's a weird one for you. I built a metal case for my carputer and mounted the M4 upside down in the lid. It would run perfectly as long as the lid wasn't all the way closed. When I closed it and tried starting computer the system would shut down in a few seconds without booting. I tried a lot of things. Here's a link to my worklog:
    1988 C4 Corvette
    I finally hooked a usb cable up and ran the M4 ATX utilities. It says I have firmware version 2.0 (I only thought they were up to 1.3).
    The PC booted correctly even with the lid on! I removed and connected the USB cable a half dozen times and it always worked with the USB connected, but never with it disconnected.
    So for you folks having problems with your M4-ATX acting possessed and starting/stopping strangely, either try not using the power on cable, or try connecting a USB cable.
    Ron
    Feb 2009
    I do not have m4 but somewhere I read that mounting holes on the M4 psu have power on them so when you use those holes to screw and mount the PSU on a metal box, make sure you put some plastic or something in the middle of the screws....
    May be they fix this issue now I said that just in case....
    There is nothing impossible in the world :-)
    Aug 2009
    Thanks for the reply, that is also one of the things I tried. I actually used nylon screws with nylon stand-offs and had the same exact problem. I was sure that would fix the problem, but was sadly disappointed.
    Ron
    Sep 2007
    Florida
    im having issues with the M4 big time......i sent the first one back as it barely worked with a VB700mobo....i have an ECS945g that wouldnt work at all with the M4....they sent me a 2nd one, and it didnt do anything with either board.....ive been swapping emails with em all day trying to figure out the deal. I know its not me as ive been screwing with car computing for yrs. keep the info flowing
  1. M1 ATX Problem 5v Rail Under Voltage
    By uhohrobbo in forum Power Supplies
    Last Post: 04-20-2008, 12:50 PM
  2. Replies: 8
    Last Post: 04-16-2007, 06:59 PM
  3. very strange power problem
    By Dj-[NRG] in forum Car Audio
    Last Post: 04-11-2007, 03:41 PM
  4. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  5. ATX PC startup problem
    By SuperMatty in forum Power Supplies
    Last Post: 10-29-2001, 12:39 AM
