Results 1 to 2 of 2
Thread: Is the M4-ATX the only high output PSU available in the UK?
    Oct 2007
    I have looked for a distributor for the Opus 360w and the DSATX and can't find UK distributors.
    Having read a LOT of threads about problems with the M4-ATX I'm a little wary about using it as I intend to use all the functionality on it (rather then as just a dumb PSU).
    The setup I have I think is going to need about 240w (I haven't received the mobo yet but intend to kill-a-watt on a testbed when I receive it).
    Suggestions please.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The M4 problems were with the first two firmwares, the lastest ones shouldn't have any problems.
    I had an early one and it only worked on the 1 minute shutdown, someone reflashed it with the later firmware and now it does the other timings.
  1. m4 ATX power supply question
    By icet in forum M4-ATX
    Last Post: 07-23-2009, 10:43 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
  4. Opus ATX and ITX PSU - Difference?
    By phoTToniq in forum Power Supplies
    Last Post: 09-22-2003, 04:21 AM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
