Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: M4-ATX Software? Does it work?
  1. #11
    Low Bitrate RonsRed88's Avatar
    Aug 2009
    Western Washington State
    Quote Originally Posted by timmay33 View Post
    I have the usb cable connected and am getting the voltage and temp information from the m4 so the connection is good.
    I have been trying to update the Thump setting from 3000ms to 45000ms. I click send and nothing happens. I believe its supposed to show some message that its worked?
    When I next fire up the car the amp comes on after 3 secs. But when I run the M4 software again it says the setting is 45000ms.
    I am using the thump pin that is inside the plug with the usb and mb on/off pins. Should I use the other header (J8)?
    The software says I am running firmware 2.1
    Anyone know whats going on?
    I have the same problem with my M4. I sent e-mails to Mini-Box and finally received a reply. I've posted my e-mail and their reply below. and if I've done it right the new firmware should also be attached. I haven't used the new firmware because I found ways around the problem before they responded, but the M4 working correctly would definitely have been best.
    Good Luck,
    Ron
    (e-mail from Mini-box 5/18/2011)
    Dear Sir,
    Thank you for contacting us and your interest in our products! We are sorry for the late reply. Have you tested another timing mode and see if you can change the thump timeout? Can you please reset the power supply? Just in case, i have attached the latest firmware for the M4-ATX power supply. Looking forward for your reply.
    On Thu, 28 Apr 2011, xxxxxxxxxxxx wrote:
    > Hello, I've been using an M4-ATX for over a year and have always had a
    > problem with the timing of the anti-thump feature. I sent an e-mail
    > last year but never received a response. I'm hoping you may have a solution now.
    > The problem is, I'm not able to change the timing for the thump timeout.
    > When the ignition is turned on the anti-thump signal is sent at 3
    > seconds, then the PC is turned on at 5 seconds and I get a loud thump
    > through the amplifier. The configuration software appears to be
    > working because the values I enter for the delay stay in its
    > configuration even after shutdown and I can also see the voltage and
    > temperature readings in real-time. I've tried numerous values for the delay without any effect on the actual timing.
    > I've also tried setting the value and then removing power without any
    > success. I have the 2.1 version of the firmware. Is there anything I
    > can do to make the anti-thump delay change?
    > Thanks
    Attached Files Attached Files
  2. #12
    Jan 2013
    Quote Originally Posted by RonsRed88 View Post
    Good Luck,
    Ron
    Dear Sir,
    > Thanks
    sorry to bring this up again, but have they ever told you HOW to upgrade the firmware???
    I'm still having some trouble with the anti-thump function and I'd like to at least try upgrading the firmware..
    send them an e-mail but don't expect a quick responce.
    thanks!
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by sanscorp View Post
    thanks!
    Quote Originally Posted by Enforcer View Post
    Quote Originally Posted by knownchild View Post
    How do you update the firmware?
    http://www.mp3car.com/power-supplies...ur-m4-atx.html
  4. #14
    Jan 2013
    ****e, not simply done then... not even the latest firmware is posted on the mini-box site.
    Allready have 2.1 but I see that 2.4 has been posted here.
    maybe... some day..
    for now I had to reset to factory default 10 times via jumper and SW and the finally it went back to FD.
    The thump timer still doesn't work, will need to buy some timer relays or something.
    still think it's way to buggy for over 100 bucks worth of hw.
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I had another member do mine for me.
    But he is in the UK and it was along time ago.
    Maybe someone who has already got the lead and programmer can offer to do it for you.
    Also there was a user who was doing reprogramming of the M2-ATX chip, he might have the equipment to do the M4-ATX as well
  6. #16
    Jan 2013
    well, in the meantime I searched what the components would cost me:
    I ordered all components double and I'm stuck at 3 euro's of the minimum 5
    So I'll just go on with this, Don't really understand the schematic that well but will ask that later.
    no hurries.
  1. How does mac in car work? (software)
    By jellymonster in forum MacCar
    Last Post: 10-25-2009, 03:45 PM
  2. Replies: 28
    Last Post: 07-22-2009, 04:23 PM
  3. Questions on software/frontend (will this work?)
    By Paracelsus in forum Software & Software Development
    Last Post: 05-10-2008, 05:25 PM
  4. Best GPS software that will work embedded?
    By WiCKeD 5.9L in forum Media Engine
    Last Post: 11-15-2007, 12:47 AM
  5. Looking for a better software to work with OBDPro
    By It's A Honda in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-20-2006, 07:40 PM
