Originally Posted by
OldSpark
13.6V will still charge it (despite what many seem to think; but it is not enough to reverse sulfation that forms when not fully charged), but that might be easy enough to fix/boost later unless it is a single-wire alternator with a D+ (charge-Lamp) terminal only (not counting the obvious B or B+ = 12V output, and the ground via body/chassis/engine).
[ You merely insert a diode in he alternators Sense line (S else I = Ign). That's a ~0.6V boost = 13.6+.6 = 14.4V for a mere ~5c to ~20c cost (unless you live in Australia where you might prefer to buy a 5c diode or 2 mounted in a fuse for a mere $35 + $7 P&P - after all, you pay for quality don't you... LOL!). ]
I'd suggest having the battery tested before buying a new one, though your info seems conclusive....
A good battery will hold charge. Its open circuit rested voltage (ie after its post-charging surface charge is removed) should indicate the percentage of capacity remaining.
IE - using my Rules Of Thumb, a full battery is 12.67V - ie, 12.7V but let's use 12.6V. Each 0.1V drop is an ~10% drop in capacity (from 12.7 being full to 11.6 to 11.4V being 100% discharged).
Hence 12.1V = 12.6V - 0.5V = 5 x 10% = 50% discharged.
The problem is that those voltages are open-circuit - ie, with load(s) removed (and a bit of self recovery time), but at low loads (line 1A etc) any difference should be negligible. For high loads, there is a voltage drop (eg, 12.6V full drops to 12.4V with lights on, but it is still full - the internal resistance drops voltage according to internal resistance (ESR) times current), but that voltage drop will remain fairly constant for a while (it increases as ESR increases with the decreasing capacity remaining).
Confused?
Anyhow, a good battery should start from ~12.6V and drop to ~11.6V linearly.
But that measures its ACTUAL capacity. Like my 6-8 year old batteries that looked okay from 12.7 to ~11.5V but only had maybe 5AH capacity instead of their rated 40AH capacity.
That's typical of older batteries, or batteries that have had a tough life (excessive flattening; long storage periods; insufficient charging; excessive current demand; high discharge & recharge rates).
Sorry for the blurb, but that's the FYI info so you can hopefully understand, or confirm yourself.
