Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 101
Thread: Doesn't hold standby power if I crank the car right away
  1. #51
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    I got the replacement M4-ATX in today and I swapped it out with the old one. I will replace the battery this evening and will run for a while to see how things are doing after some real world tests.
    My assumption is that I still need some supplemental charging because of my driving habbits ie. taking lots of short trips through the day and long periods (2 or 3 days at a time) of just sitting.
    I will cross that bridge though after I replace the obvious.
  2. #52
    Jan 2004
    California
    So I just got the new battery all wired up and I took some numbers.
    @ the aux battery while idling it measures 13.51v (isolator connected)
    The Aux battery measured 12.75v (isolated)
    Standby current is roughly .3amps
    We will see how far it is drained when I test it tomorrow
  3. #53
    Jan 2004
    California
    When I tested it the next day (roughly 10 hours) it was at 12.46v which is a marked improvement proving that the battery was indeed bad. After a short trip with the alternator charging it was back to 12.6
  4. #54
    Raw Wave
    Nov 2009
    As I just wrote in the Why is my voltage dropping? thread - and elsewhere if not in this thread - a battery just off charge should be up to ~13.6V due to surface charge which then drops over 12-24 hours (with no load) to its nominal full voltage (12.67V, but say 12.6-12.7V).
    13.5V is ok assuming that at idle, the alternator output has dropped. It certainly isn't discharging the battery, though long-term it is insufficient to charge it, and will wreck the battery without occasional equalisation charging (over 13.6V, usually ~14.4V) to blow away soft sulfation.
    A modern alternator (ie, after ~1960?) should charge the battery with 13.8-14.4V with 14.2V being a common set point. That's at the battery - the alternator may put out more.
    In theory, except for single-wire D+ alternators, the alternator should be sensing the battery voltage and hence the alternator compensates for voltage drops to the battery.
    But the second/remote battery may see a voltage drop due to its distribution current & resistance (ie, V=IR where V is the voltage drop; I is the current along the distribution (fuses, cable, relay/isolator AND ground path) which has a total resistance of R Ohms.
    As long as the remote batteries are generally near fully charged and occasionally see at least 13.8V they should be ok (assuming it isn't excessively discharged). (EG - normal batteries are discharged when cranking, but then have the trip to recharge. When the trip ends, its a fully charge battery. Audio-system batteries that are not fully charged are left in partial discharged states which cause sulfation.)
  5. #55
    Jan 2004
    California
    So it appears that i should have read all 27 pages of the "Everything you need to know about M4-ATX" thread
    Apparently on page 22 it states issues with the IGN line being flakey in regards to holding standby current. The solution... Diode and a Cap on the IGN line.
    Everything You need to know about your M4 ATX
    So far switching from ACC to IGN has worked out well for me but i still have some unresolved issues:
    http://www.mp3car.com/m4-atx/148142-...off-cycle.html
    I will be adding this soon (RMA'd my motherboard)
  6. #56
    Raw Wave
    Nov 2009
    One problem with the diagram as shown on that Everything You need to know about your M4 ATX link is that the Standby Battery (and LCD and M4-PSU) get about 0.6V less than the IGN +12V.
    Not that that should be a major problem - it merely means the Standby Battery may suffer from inadequate charging.
    [ The cap should still hold sufficient voltage, though if the M4 can suffer because its IGN voltage is much higher that its + (Standby Battery) voltage, a diode should be inserted from the cap to the + (Standby Battery) so that it can discharge to the + voltage.
    And not that I understand why the relay is there - as I read it, it is on whenever the Standby Battery is connected (and with sufficient voltage) OR when the IGN is on - why not omit the relay entirely? ]
  7. #57
    Jan 2004
    California
    Thanks for taking the time read that. Ignore the majority of that drawing. Just the part of the capacitor and the diode on the ignition line was the part I was referencing.
    The purpose is to make the IGN line a bit more stable. IMHO if the IGN line is that sensitive than it seems like a good idea to me.
  8. #58
    Raw Wave
    Nov 2009
    Phew!
    Yeah - just a diode to the cap which is at the IGN (sense) input.
    PS - I didn't read fully - just skimmed for and updated diagram else comments that stood out (but my 3D glasses detected nothing LOL).
  9. #59
    May 2010
    Australia
    Argh terrible pun terrible!
    Lucky I haven't been keeping up with this thread so closely!
  10. #60
    Jan 2004
    California
    Quote Originally Posted by OldSpark View Post
    Phew!
    Picked up the cap and diode today, will be installing it shortly.
  1. Failure to hold standby state
    By Seth_jxl in forum Power Supplies
    Last Post: 10-10-2008, 09:35 AM
  2. Turning key from ACC to Crank = Laptop will standby
    By l00kster in forum Power Supplies
    Last Post: 11-15-2007, 02:27 PM
  3. Power Supply crank issues
    By jaytyn in forum Power Supplies
    Last Post: 11-03-2005, 01:44 PM
  4. Replies: 5
    Last Post: 05-26-2004, 01:55 AM
  5. ITPS/Power Hookup (...Crank won't bother me)
    By rockthevolvo in forum Newbie
    Last Post: 02-06-2004, 08:32 PM
