Originally Posted by
Mickz
As far as interference to the screen goes, the M4 should not really impact on that, however with the quality and unshielded layouts on some LCD displays nothing would surprise me.
In all noise testing I carried out with the M4 I never once encountered a problem with video. I run a 5M VGA cable from the rear of the car to the Display, no interference on the coax reversing camera run either, if the M4 was causing a problem this is where I would expect it to show up. My Monitor is powered from 3 sources, +12v output from the M4, +12v reversing light supply and program controlled switched +12v for recording while driving.
Like most Switch mode supplies the M4 generates quite a bit of noise, however it’s more the spectrum or bandwidth that the noise from the M4 covers. Starting from Audio through VHF and extending above UHF and Sat Nav frequencies – that’s the problem in the M4.
