Results 1 to 6 of 6
Thread: M4 Questions and help
    Dec 2010
    So im looking at purchasing the M4 for my new carpc that is going in my 05 neon show car, and i have a few questions about wiring it for auto turn on as well as a few other concerns.
    1) can the ignition wire be hooked to the remote wire for my amps (with a relay)
    2) if i cannot do #1 is there a way to wire it so that i can have it running without starting the ignition.
    3) is there anything else i need to purchase to do the above other then the ATX case for it?
    Jan 2008
    1+2.the ignition trigger gets connected/powered just like a amp trigger connection, so yes, there should not be any issues connecting it that way.
    3. switches, and power calculations/power adapters to be sure that you can run the required amount of time without starting the motor.
    Dec 2010
    Thanks!
    im not too worried about how long it will run as i have a ac to DC converter for running my A/V at shows
    but does the M4 come with everything i need to hook it up to my computer (other then power and remote wire) to make it turn on and off?
    Jan 2008
    it should-- it includes the 20-pin atx power cable+ p4 power adapter, and the small power-button jumper cable. though, if i remember right, the usb connection cable is not included, so you either need to make one, or order one separately.
    Dec 2010
    where can i order the usb cable? only thing i could find on here is how to build one, and im not that comfortable doing so....
    Aug 2010
    Here's a link to where you can get it in the MP3Car Store: http://store.mp3car.com/M4_ATX_USB_C..._p/cbl-068.htm
  1. Few questions on M4-ATX
    By flyerman in forum Power Supplies
    Last Post: 07-14-2008, 10:01 PM
  2. Questions, Questions, Questions...
    By TomParker69 in forum General Hardware Discussion
    Last Post: 08-10-2007, 02:32 PM
  3. Just a few questions regarding GPS...
    By J7MAN in forum General Hardware Discussion
    Last Post: 03-26-2007, 05:14 PM
  4. questions, quetions, questions...
    By [ULKER] in forum Newbie
    Last Post: 08-01-2006, 11:12 AM
  5. Questions about running cable, also powering questions
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-31-2001, 10:36 AM
