http://www.youtube.com/watch?v=3phkQ6bmJvo
Try this....first time I tried uploading to youtube
Occasionally when I resume from standby my computer tries to resume... it fails and then gets stuck in a power on power off cycle...about every 5 seconds.
For me to clear this I have to to the car off and let it sit for a few seconds and then start again...most times this fixes it...if it doesn't then I have to remove the power from the computer. I have video I will try to post
Bump
I RMA'd my M4-ATX. Here's to hoping that the new one that comes in has the issue resolved.
Not entirely sure the M4 is the problem although it is suspect at this point. Also on my list of potential root causes is the Aux battery (I will be replacing that as well)
Got the new M4 in and for good measure I replaced my Aux battery.
Here's to hoping the issue is resolved
Since it look likes I am on my own with this issue at this point I can only hope that this helps someone experiencing similar issues...
BTW even after replacing the battery (which was on its last leg) and replacing the M4-ATX I still experienced (twice today) the power on power off cycle issue.
I have been in contact with the makers of the M4-ATX and will speak to engineering some time on Thursday to figure out the next step.
In my opinion it is either an issue with the firmware or with the hardware common across all M4-ATXs, issue with my motherboard, or a situation where one of my rails is overloaded
Today I found an issue with the IGN wire. The solder joint was faulty. I replaced it with a solid connection and ran all day without the issue arising. Still testing though.
Damn... Had the problem again. It ran for almost two days without issues.
I did a fresh windows 7 build and it didn't help
Hello,
I've also had the same issue with the M4-atx power supply. I also have an annoying hum that I'm quite sure is due to this psu. There was a thread called "everything you need to know about your m4-atx" somewhere on this forum. In this thread the aforementioned problem was fixed by placing a diode in series with the ignition connection on the psu and a capacitor from the ignition line to ground.
-----------------------------------------------| \|---------------------------------- IGN on M4-atx
Diode ------------ Cap
---------- GND
