Results 1 to 3 of 3
Thread: USB Cable connection not working
    Jul 2009
    Squamish, BC
    I have a USB cable with the 4 pin header connection. If I use this cable with the PC motherboard it can successfully connect a mouse, keyboard, or thumb drive.
    When I connect the cable to the M4, I get nothing. I have the red wire to pin 5, white to 4, green to 3 and black to pin 2. The header goes to a female and then I have a male-A to male-A going to a PC usb port. The PC does not recognize a USB connection and the two software packages from mini-box both say device not found.
    I have tried with the M4 running and with it powered off. Is there anything else I need to do? Jumpers perhaps?
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Just a few quich thoughts, from memory Windows will detect the M4 as a HID device and it will show up in device manager.
    If it hasn’t detected it then unless the board is faulty, it’s obviously has to be an incorrect connection between the M4 pins and the USB type-A connector you’re using, possibly just data +/- reversed?
    As far as I can remember no switches or links needed changing.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
    Jul 2009
    Squamish, BC
    Data +/- are the correct way round. M4 just does not cause windows to detect anything connected. As the cables are working elsewhere it has to be the M4's USB not working. That's a real shame because I think a configuration change is all I need to get this thing working (just not shutting down correctly).
  1. DC DC converter extending connection cable possible?
    By 528i_tourer in forum Power Supplies
    Last Post: 01-13-2011, 11:30 PM
  2. Xenarc 705TSV - modify the connection cable?
    By Pseudo Nim in forum LCD/Display
    Last Post: 08-30-2009, 11:06 PM
  3. lilliput data connection cable
    By poke in forum LCD/Display
    Last Post: 11-15-2007, 06:23 AM
  4. BU303 USB to IPAQ 5550 connection cable
    By gaznasty in forum GPS
    Last Post: 10-04-2006, 09:47 AM
  5. Amplifier Signal Cable connection
    By Pheebs'67 in forum Newbie
    Last Post: 11-26-2005, 02:01 PM
