I have a factory bose system in my truck hooked up to a wiring harness that has a blue/white amp turn on wire. I have connected this to the inner pin of the J6 connector on my M4-ATX. This does it's job sending a signal to the wiring harness and in turn to the amp to turn the bose amp on.
My problem is I get bad audio feedback until the PC boots to the windows log in screen. Once there the noise is gone and everything sounds crystal clear.
One solution I am working on is setting up the PC to "instant on". However it would be great if I could keep the amp from coming on until I am at the windows log in.
Is there a way to modify (increase) the length of delay for the thump pin header turning on the amp? Or did I fail at some point in my setup? I do not have the ground pin (on the J6) hooked up to anything currently.
Reference pics::
J6 header
http://i163.photobucket.com/albums/t...6pinheader.jpg
Amp turn on wire
http://i163.photobucket.com/albums/t...sampturnon.jpg
