Results 1 to 2 of 2
Thread: m4-atx Case Compatbility?
    Newbie GamerGirlAlice's Avatar
    Jan 2013
    Broken Arrow, Oklahoma, United States
    which cases can hold the m4-atx psu. i really want to use a voom2 case if i can
    May 2012
    Grandville, MI
    The M4-ATX is a standard ATX style power supply. This is to allow you to put a mid tower type case in your vehicle. It will not be compatible with ANY of the cases made for car PC installation. You would have to put it into its own case and run the cables to your case.
    You are over thinking this and unless you are playing high graphic games and need a gaming card you don't need anything fancy.
  1. Double-DIN carputer case vs. Remotely mounted case
    By 04LS1GTO in forum General Hardware Discussion
    Last Post: 12-10-2012, 08:27 AM
  2. VoomPC Case With M4-ATX & TDA7850? Or Alternative Case?
    By 356Speedster in forum General Hardware Discussion
    Last Post: 02-26-2012, 04:56 PM
  3. mounted case then a case of alternator whine
    By titanicmusic14 in forum General Hardware Discussion
    Last Post: 08-28-2009, 06:51 PM
  4. Replies: 2
    Last Post: 11-01-2008, 01:06 PM
  5. What case to get and where? for an ASUS Mini ITX mobo? not a DIY case.
    By BEHMER in forum General Hardware Discussion
    Last Post: 07-31-2004, 10:01 PM
