How about this guys....
http://www.x2vga.com/
with
http://www.xenarc.com/product/700y.html
Or any other VGA enabled set?
VGA input TFT compatible with car usage (in term of size) are very rare:
lilliput and hami are the most known.
DVI input or HDMI input small screen (10" or less) are *NON*existent on the market, period.
Except those only two items i've linked to.
As ATV ca do HD, I think using a screen capable of HD is very logical,
do not use an composite input screen please (as most of japanese top brand moniceiver propose)
with
I purchased an AppleTv and installed OS X the next day (it took about 8 hours to make a backup image of the hard drive). Anyhow, it was extremely easy to do, with only a few minor annoyances. For example, the ethernet port wasn't working, and it took me about an hour to figure that out. As far as the usb goes, it is flawless with multiple devices plugged in through a belkin 4 port hub (powered). So, with that I've got the bluetooth hooked up (for the mighty mouse) an external hard drive (powered) a jump drive and a keyboard. The boot process is a trifle slow, though not unbearably so. And once the os is up, the computer is fairly quick and responsive. As an aside, the processor turns out to be 1.5Ghz, not 1Ghz. Everything was smooth an easy and I'm typing on my AppleTV right now. At the moment, this is the word processor for my house, but I for one believe this thing is more than adequate for carputer applications and I'll be installing it in my car as soon as I have a replacement.
HOWEVER, it is important to note that there has been no luck with the audio card under full OS X. So, until this issue is resolved by better minds, an appleTV with OS X is entirely useless for media purposes.
I have installed the AppleTV in my Expedition using a 15″ overhead screen for the kids in the back and a Panasonic head unit with screen for the front. I can use the steering wheel buttons to control the Apple TV using PAC’s universal steering wheel control interface. Works great. I use an inverter and video converter from svideo.com to convert component video to composite video. It is also AC so requires the inverter. I am in the process of adding a smart DC power supply with 12v/9v/5v to get rid of the inverter and to allow the Apple TV to stay on for syncing without draining the battery. The best thing about the Apple TV over the Mini for the car is it doesn’t require any maintenance, it’s auto syncing, and no keyboard or mouse is required. I will add a rear view camera so I can see behind when the 15″ screen is down.
A note to Carnetix. I took the power supply out of the Apple TV and the specs say it is a 5 volt switching power supply. It would be great if they could provide DC-DC 12v to 5V supply that fits inside.
Hey, can I just use the ATV without hacking it. I just want it to be a media storage system. I will hook my GPS up to the other RCA jacks and then just hit the AV button on my LCD. However, i will have the audio coming form the ATV so it will not affect my music I am listening to now right? Or should i just get a mac mini and hook up the gps to that and get somekind of radio app too. I'm really lost here and i need to buy this crap and know exactly what to buy. I just want to get a media server with a radio and gps in my car. I also don't know what the best front-end app is. Can someone help. thanks
If you're still curious, yes, you could just use it without hacking it and it would make a pretty good music server. The simple remote system lends itself well to car audio use. The really neat thing, I think, is that whenever you park the car at your house and you're in range of your wifi, your play-lists and podcasts will automatically be updated. Just use a head unit with an aux input, no problem.
correct me if i'm wrong, but can't you just use a component to vga adapter for the video? its all analog, and i've seen the cables
You cannot use just a cable to convert component video to VGA. These cables are "for connecting Projectors or other devices that accept Component Video (Y-Pr-Pb) into their VGA connector. This cable does not convert Component Video to RGB, for that you need a Component Video to RGB converter. You also cannot convert RGB/HV to Component Video with a simple cable, you need a converter for this". Hence the need for svideo's component video to composite converter. Someday it won't be needed when car screens go HD.
Would this help you guys out?
Full colour 480i with just 1 yellow composite cable plugged into the green composite connector on the AppleTV.
http://forum.awkwardtv.org/viewtopic...omposite#p3644
