Results 1 to 4 of 4
Thread: How do I play the audio coming in on the Line-In?
    Dec 2005
    Setup:
    Intel Mac Mini
    Mac OS X or Windows XP (via Bootcamp or Parallels)
    HQCT (High Quality Car Tuner module, outputs radio on Line-Out)
    etc...
    I've hooked up the HQCT and can record live radio using Sound Recorder. It plays back just fine. However, I can't figure out how to play that sound in real time without recording it first. Isn't there a standard setting that will allow the Line-In to pass through to the internal speaker or headphone jack?
    Recording it in Sound Recorder worked in both Parallels and booted using Bootcamp. In Mac OS X I could see the input registering in the control panel but don't know of a Sound Recorder equivalent in Mac (plus my install will probably more Windows centric).
    I also tried to pass through the Line In on my Dell Inspiron 6000.
    Questions similar to mine have been posted here before but the threads didn't point to any solutions. Is this a limitation of the sound controller and it's drivers that can only be remedied with an external sound card? Anyone solved this yet?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You need an external device like the Griffin iMic to get input into your Mac. Once you've done that, you can use LineIn. It provides pass through of sound input. It's free.
    Also, have you tried connecting headphones to the HQCT output and listening to it? If you can hear it, then then HQCT is working correctly and it is simply a configuration issue.
    Want to:
    Dec 2005
    Yes, it's just a configuration issue. Like I said - I can record the HQCT sound using Sound Recorder under Windows. The HQCT is working. The only problem is being able to hear the sound.
    LineIn did the trick. I downloaded and installed it and it worked right off the bat.
    Quote Originally Posted by Bugbyte View Post
    You may not be aware of this, since you have a PPC Mini. The Intel based Mac Minis do have a line in feature.
    Now all I need is the equivalent of the LineIn software that works under Windows. Anyone know of such a beast?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by timeshifter View Post
    Nice. Yet another reason to upgrade...:-)
    Want to:
  1. OEM Navigation Connectors
    By Mr Castulucci in forum General Hardware Discussion
    Last Post: 07-20-2010, 05:25 PM
  2. Trouble w/ XM Audio playing...
    By kristiandg in forum StreetDeck
    Last Post: 11-03-2006, 07:42 PM
  3. Problem compling rr with latest source code
    By Sonicxtacy02 in forum Road Runner
    Last Post: 07-02-2006, 05:08 PM
  4. Audio play back issue
    By lukee858 in forum Newbie
    Last Post: 11-24-2005, 08:06 PM
  5. can't play real audio files
    By Wax Man in forum FrodoPlayer
    Last Post: 01-31-2005, 04:11 PM
