Results 1 to 5 of 5
Thread: Notification windows steal focus
    Constant Bitrate zapwizard's Avatar
    Aug 2002
    Austin, TX
    When my Mac Mini wakes up from sleep and front-row is running, applications in the background keep steeling focus right at wake-up.
    Namely the WIFI notification window asking me to connect to what ever WIFI point is nearby.
    I don't want to disable the WIFI as I use it to connect to the mini at home. There is no option to disable that prompt that I can find.
    Does anyone know of a way to force Front-Row to regain focus?
    Right now i have to do a left-mouse click to get control back in front-row. But a applescript that simulates a mouse click doesn't seem to do the trick.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I have similar problems when my internet connection drops. It throws up a prompt message telling me it is offline. You have to click to clear it.
    Anyone? Anyone??
    Want to:
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    In your own application, you can tell a window to go to a layer that is above these notification windows - this is what we are using in QCar. See the CGWindowLevel.h file in the CoreGraphics framework for more details on the levels.
    Of course you can't use this with standard applications that you do not control on the source code level. And I don't know about any other trick you could use.
    Edit: Bugbyte, you can get rid of the disconnection messages by not using Internet connect application or auto-connect in OS X. If you use pppd from the command line, there won't be any dialog boxes. I have to check the exact instructions for using pppd though - it is not as easy as one would expect on Mac OS X.
    Aug 2002
    Austin, TX
    Well I got rid of the pop up window, but when the system comes out of sleep FrontRow still losses focus.
    I think what I am going to do is just make FrontRow exit on sleep, and re-open on Wake.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Jirka Jirout View Post
    I like the auto-connect feature, though. Can you similarly command pppd to auto-connect when needed?
    Want to:
  1. Ahhhhh Windows Can Blow Royally
    By Sidewalksalvage in forum Off Topic
    Last Post: 01-25-2007, 02:17 PM
  2. Lauching embedded programs. New windows lose focus
    By ddogg_777 in forum Road Runner
    Last Post: 04-21-2005, 09:59 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  4. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
