Results 1 to 9 of 9
Thread: Port Mapping....!!!
    Jul 2006
    London
    Port Mapping....!!!
    Right guys....
    I'm on a mission, i have an internet connection in my car, and i am looking to do something a bit different, not too sure how it will work, but looking for some advice...!
    I am going to run http://www.securityspy.com/ in the car, but i don't understand port mapping...
    I am going to set it up on my home network 1st on an iMac...
    I run through a BT Home Hub which is connected to an apple extreme and then wireless into the home network. I have got as far as i can do this on the home network between machines, but don't understand the mapping to be able to view over the net...!!!
    If i can get this set up at home, then i will run this in the car, so people will be able to view the camera(s) from the car on any mac and see what i see, just a gimmick for some, but it will have 2 cameras, 1 forward facing and 1 into the car itself...
    Any help would be appreciated..
    CLICK ME
    Smart Car due for completion beginning of march....
    Log with pictures to go online shortly after.
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    The feature you are looking for is also called NAT or address translation. Basically what you need is to tell the router to take incoming connections on its public interface and a certain port and forward it to certain address and port on the internal network.
    Jul 2006
    London
    I got that far, but i don't know how to do it... lol
    been reading up on it, but i am still a bit confused.
    CLICK ME
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Typically there is a page for it in the Advanced settings for the router. On my SMC, it's a simple form that lets you specify the port as well as the target IP address (I believe some will let you map to a different port too, e.g. port 22 ->192.168.2.100:9999).
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Who makes your router? IE, (interweb)--->(your cablemodem/dsl modem)-->(your router)--->all the computers on your network. Basically you have to set port 8000 (the default for security spy) to be forwarded to what ever the ip address is on the machine you have it installed on.
    Failure is not an option....
    It's installed by default on every version of Windows.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Which you can find here....
    Want to:
    Jul 2006
    London
    The modem/router is a BT Home Hub (which is disabled for wireless and used as a modem by ethernet to the Apple Extreme router, which IS wireless and has an iMac connected to it and that has the cameras...!
    Any machine on the home network can see the cameras using http://192.168.1.274/8000 which is the ip address of the machine they are connected to i assume...
    So now i need to work out the rest...
    Does that explain it a bit better from my end...?
    CLICK ME
    Newbie KRS_Juan's Avatar
    Mar 2007
    Los Angeles
    In your router, in port mapping/forwarding, tell it to forward all requests on port 8000 to 192.168.1.274.
    Now to see the camera's remotely load up http://yourexternalIP:8000
    So if your external IP address was 127.0.0.1 it would be http://127.0.0.1:8000
    -KRS Juan-
    Aug 2007
    did you ever get this up and running?
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 09:26 AM
  2. Opening virtual gps com port.
    By EricE in forum Software & Software Development
    Last Post: 03-19-2007, 12:51 PM
  3. SDK commands over the serial port ????
    By tolisn in forum Road Runner
    Last Post: 12-14-2005, 12:03 PM
  4. Replies: 4
    Last Post: 07-04-2005, 04:38 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
