Results 1 to 4 of 4
Thread: Xenarc 700tsv help
    Jan 2007
    Xenarc 700tsv help
    ok, so this is my first post... didnt think i would need to ask for help since this place is loaded with info. anyways..
    so i tried different settings with display config x and i searched all around the AMP forum also for a setting that will allow AMP to work full screen. When I power up, everything works fine, until i start up AMP and the program isn't full screen. AMP sits on the lower left hand side of the screen. When i run a visual on the music screen, the whole screen fills up. is there a way to configure AMP to fill the screen?
    Im using a 1.66 intel core duo mac mini.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The proper settings using Display Config X are discussed in this thread.
    Want to:
    Jan 2007
    roger, i tried all of those settings, but i had to tweak them on my own by figuring exactly how display configx worked. thanks.
    guess i was just tired!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think you have to delete all of the other resolutions. Getting it to 'stick' is discussed at the end of this thread
    Want to:
  1. Xenarc 700TSV Doesn't Fit
    By zzzBrett in forum LCD/Display
    Last Post: 01-30-2007, 03:13 AM
  2. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 11:55 PM
  3. Pandora w/ Xenarc 700TSV and Barrel Connector
    By froalskiner in forum General Hardware Discussion
    Last Post: 07-20-2006, 03:39 AM
  4. Xenarc 700TSV Resolution
    By blackflux in forum LCD/Display
    Last Post: 05-18-2005, 02:51 PM
  5. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
