Results 1 to 6 of 6
Thread: Tiger Virtual Memory Issue
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    Hi guys,
    I have a Powerbook G4 1GHz with 1.2GB of RAM.
    I think it's rediculous that when I have my Torrent tracker, Firefox, Adium, and Pages open, that when I look at my activity manager, I'm using close to 3GB of Virtual Memory.
    1.2GB should be MORE than enough to be able to handle this using little or no v. mem.
    I don't want to completely turn it off, because I know that sometimes it's important, but I want to limit it to only maybe 1GB or so...
    Thanks,
    Rafster
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    What does "using close to 3GB of Virtual memory" mean exactly? Is this the total size of the allocated memory? Or the sum of the allocated memory of the applications? VSIZE? RSIZE?
    Does the computer work? I guess it does. So just quit Activity Monitor and let the OS do its job. Unless you really know how things work (in which case you would probably not be posting stuff like this ;-) ), the chance you can improve them is pretty minimal.
    Just for your info, this is what things look like on my MBP with 2GB RAM with some 11 apps running (plus the system of course).
    Code:
    Processes:  88 total, 2 running, 3 stuck, 83 sleeping... 356 threads   17:36:35
    Load Avg:  0.65,  0.56,  0.47    CPU usage:  7.56% user, 10.67% sys, 81.78% idl
    SharedLibs: num =   12, resident =   57M code,  276K data, 4024K linkedit.
    MemRegions: num = 15325, resident =  603M +   20M private,  847M shared.
    PhysMem:  252M wired,  789M active,  571M inactive, 1612M used,  428M free.
    VM: 12G + 368M   696345(0) pageins, 910637(0) pageouts
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by Rafster View Post
    I know FF and Safari 2.x can be VM hogs if you leave them running long enough. Usually quitting them and restarting frees up most of the memory, but not all. Apple drastically improved Safari's memory foot print with 3.0, so you might want to try it out over FF (I had switched to FF, but have gone to Safari 3.0 now).
    I've had pages on my dual 800 G4 running for a couple of weeks now, and it's only using about 500MB between physical and swap so i'd say it's pretty stable. You might want to watch your tracker.
    That isn't really true in a modern OS like it used to be in the days of Window 3.x and 95. OS X uses the design of swapping out inactive memory whenever possible rather than stuffing the physical RAM full to the brim (Linux likes to do this). Each methodology has it's benefits, but Apple selected the best case for a desktop environment (I don't know if Server uses the other method or not) as the average user is only going to be using a small number of programs at once.
    There used to be a way to move the swap partition to another disk in 10.1 (and maybe 10.2?), but I haven't seen it since. This was more for performance gains (e.g. reduce contention if you were doing large numbers of reads/writes while also swapping) rather than controlling the size (though you could do that as well).
    Jirka is right. Trust that the OS is doing the right thing. What you need to do is track which programs are eating up your RAM and VM, then complain to the developers/vendors that they need to improve their memory management and track down their leaks.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Jul 2005
    Netherlands
    Quote Originally Posted by iamgnat View Post
    It still works, we are playing around with this as a part of our experiments with booting from a solid-state storage devices (the computer boots from a CF card while swap and some data is on the hard drive).
    Jul 2004
    NoVA
    Quote Originally Posted by Jirka Jirout View Post
    Really? The info I had doesn't work any more as they had changed how swap worked either in 10.2 or 10.3. Can you send me the info you have on it? (yes I like being that anal about partitioning )
    -dave
    Jul 2005
    Netherlands
    Ups, maybe I was not 100% clear. It is still possible to achieve this, but you have to use a different method:
    http://www.math.columbia.edu/~bayer/OSX/swapfile/
  1. What is the optimum amount of memory?
    By Snootch in forum Newbie
    Last Post: 05-30-2004, 01:51 PM
  2. Power Seat Memory
    By llmask in forum General MP3Car Discussion
    Last Post: 03-22-2004, 12:14 AM
  3. Via Epia 800 Memory issues...
    By gospeed.racer in forum General Hardware Discussion
    Last Post: 02-27-2004, 02:51 PM
  4. Help with Real DOS, memory managers, and sound card drivers
    By bombboyer in forum Software & Software Development
    Last Post: 04-11-2003, 07:10 PM
  5. Disable Virtual Memory?
    By SexyCompGeek in forum Software & Software Development
    Last Post: 06-20-2000, 06:57 PM
