Results 1 to 10 of 11
Thread: Computer audio noise from Intel 2 ghz mini
    Newbie dogpilot's Avatar
    Oct 2007
    Flagstaff, AZ
    Well I went for a 2ghz Mini to install in my Vanagon Syncro. I managed to get a Carnetrix P1900 with the extra 5V output to drive a USB hub. This all is connected to a Lilliput 841 mounted on the ceiling. The touchscreen interface is working just fine. I have got it running Routebuddy with a Etrex Vista Hcx going in through the USB hub.
    I have connected the audio output to my Panasonic 8304 stereo's AUX input.
    Unfortunately, I get computer noise in the audio on the Panasonic. I isolated each output, screen, hub, and screen power (by installing a relay on the secondary output of the 1900, and running it on its own power supply).
    So any suggestions on getting the noise to go away. Would it get better if I perhaps went to a USB sound output?
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Sounds like you have a ground loop. Check over in the Audio forum (or maybe it's in the FAQ section?) for a great write up on finding and fixing them.
    The jist is that you need to either try moving your various ground points around or pick up a ground loop isolator (though they don't always work).
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Oct 2007
    Flagstaff, AZ
    Well ground loop is defiantly a possibility. I am getting more computer noise feedback. I need to check the ground on the power cable shield as well.
    I did a little trip to Fry's Electronics today and picked up a few essentials, a better shielded audio cable and a Creative USB audio output. I can locate it closer to the Audio amp, and it will be isolated from the computer's generated noise that can be generated out to the audio line.
    More experimentation tomorrow.
    BTW, I did read that thread, sometimes there is other wisdom to be gained from the community as experience grows.
    Jan 2007
    Interested to see your final set up in the Syncro, I'm just pulling everything together to install into my 89 Westy...
    Feb 2004
    Spartanburg SC
    If you did not use the mounting plate (metal thin cover for ports) you probably are not fully grounded. On my jetway had to solder a wire on the metal connectors in the back (USB, Firewire Etc) to each other and then ground. Solved all my noise problems
    Oct 2007
    Flagstaff, AZ
    I have some photos of the early version of the install using a G4 Powerbook. It just didn't fit anywhere without some kind of issue. That coupled with the fact it had to be started with the lid opened, then you could close it, made it a poor choice.
    I just had the van painted, so the windshield was off. That gave me an opportunity to have some holes drilled in the back side of the glarescreen so the wires where neater. I had temporarily mounted the Mini on the heater box in the same position as the G4, but there is an issue with shifting on the Syncro. So, I have bought a spare glovebox assembly and am in the process of mounting it in there.
    The least fun of this whole project was pulling the VGA cable down the A pillar. I had to cut and solder it besides maneuver it through a maze of thin openings and sharp metal edges. The noise thing is irritating, but I mainly put the system in for navigation. I will have to do some more EFI steps on the Mini. Sounds like the Cold War all over again, I will have to make it 'Tempest' safe.
    If your interested in the Syncro, there are some pics of the Kitchen unit mod I did, and scroll down the page to the computer part and the recent paint job.
    http://homepage.mac.com/greystoke.eng/PhotoAlbum12.html
    Oct 2007
    Flagstaff, AZ
    Well by improving the shielding on the power cord all the way to the plug and incorporating a metal foil tape over the remainder of the exposed wires. This was all encased in adhesive heat shrink tubing. Noise went down substantially. I also got a very high quality patch cord for the line out to the AUX in to the Panasonic Stereo.
    I picked up a Creative USB Audio output port. I thought the line out direct sound was great (when no noise was present). Well I was wrong. It is hard to describe, but the sound has a lot more depth and almost all the noise was eliminated. It was worth the experiment. Output sound is now better than when sourced with CD's or XM.
    It seems that most of the output lines will radiate a bit of noise from the P1900. So I will go back with some shielded wire we use in avionics installations to eliminate any possible remainder for the power button line.
    Jan 2007
    cool, some interesting stuff you're doing with the install...
    I thought about cutting away the passenger side of the dash to make a mounting place for the mini, but my new westy is very very original so don't really want to start chopping it. Getting a VGA lead up the pillars has definitely put me off a roof mounting
    Oct 2007
    Flagstaff, AZ
    I really wanted to avoid cutting up anything as well. I finally found the solution for the cable in the pillar. I used a rather stiff piece of household electrical wire to snake down the pillar. I took off the button for the interior light. I could push through this small hole to push the wire over to the hole the door wiring goes though and grab it. Once that was in place I pulled down some strong nylon flat web, about 1/4" wide. I first pulled the cut VGA cable, which also carried a USB cable internally as well. Then I pulled power for the screen. I left a piece of the nylon in place so if I decide to pull anything else, its already there.
    I bought a spare glovebox assembly, complete for $15 shipped off ebay. I will modify this to hold the Mini, Mounting on the heater box was just too close to the shifter. There is loads of room under the dash, in front of the glovebox to mount power supplies and other expansion items.
    Nov 2007
    Interested too
    I'm interested too in how this works out for you. I was just starting to think about putting a mac mini in my 86 Syncro Wolfsburg Weekender.
    How is it having the liliput mounted the the ceiling where you do? It seem a little hard to see and work with for GPS navigation. I like having my GPS on top of the dash pod. With a PC in the van to drive GPS I was thinking about a 7" screen just left of the ash tray, but I haven't really researched that yet.
    Also why put the mini in the glove box (which seems totally reasonable to me) rather than under either of the seats (which seems equally reasonable, if not preferably). Just wondering what your thought process was?
    Finally how are you running power to the Mini? 110V AC or something else? This was always the reason I've leaned towards using a laptop.
    Looking forward to more reports on your progress and results
    -Jon
  1. Mac mini (Intel) and CNX-P2140
    By atl in forum MacCar
    Last Post: 09-06-2010, 09:18 PM
  2. Audio issue with Intel Mini
    By iamgnat in forum MacCar
    Last Post: 06-27-2006, 07:01 PM
  3. Shuttle sv24 or fv24
    By michael_16j in forum General Hardware Discussion
    Last Post: 06-05-2006, 02:56 PM
  4. Intel Mac Mini on TrailBlazer 2002
    By tizoc in forum Newbie
    Last Post: 04-19-2006, 01:03 PM
  5. audio noise when scheen is on
    By Dave_Perth in forum LCD/Display
    Last Post: 07-22-2005, 04:58 PM
