Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Leopard
  1. #11
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    Quote Originally Posted by Jirka Jirout View Post
    I have recently experienced an issue with deep sleep - instead of waking up, the mini just boots up.
    That I also noticed in Tiger. Did it always work for you in Tiger?
  2. #12
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Quote Originally Posted by godraj View Post
    It did, but I have switched to Intel mini now as well - so the problem may be related to hardware, not OS version.
  3. #13
    Jan 2006
    east coast NY
    Ahhh IC. Are all your USB's going to into mini or self powered hub? And how well did they all recognize when it woke from safe sleep.
  4. #14
    Jul 2005
    Netherlands
    Only HQCT eA is connected directly to the mini. All the remaining devices are connected using two hubs (in a chain) and the power of these hubs is completely isolated from the Mini. And AFAIK there was never any problem with recognizing the devices - either on my PPC or on Intels of my colleagues and a few customers.
    As a matter of fact the only two USB devices causing problems are USB modems for CDMA (EVDO-1?) and 3G (Huawei E220). These sometimes just stop working and need to be re-plugged, sometimes they disconnect so long that sleep or shutdown attempts can't be completed etc.
  5. #15
    Jan 2006
    east coast NY
    That's interesting. What version of the P1900 firmware are you on? The reason I ask is because I noticed the same issue before Mike had extended the ACPI pulse about a year ago. 6 months ago there was another update that extends the pulse to 1.7seconds and also prevents mini from going into overcurrent. I think this is more apparent for Core 2 Duo machines, although I did notice it with the Core Duo's as well. So if you haven't done the update, it MAY fix your issue.
  1. FrontRow Remote
    By CArringt in forum MacCar
    Last Post: 05-28-2008, 06:07 PM
  2. Leopard and CFE - working fine
    By Bugbyte in forum CarFrontEnd
    Last Post: 11-09-2007, 07:27 PM
  3. Replies: 4
    Last Post: 10-30-2007, 10:45 PM
  4. Mac mini (PPC) deep sleep
    By Jirka Jirout in forum MacCar
    Last Post: 10-14-2006, 02:58 PM
  5. Can A Leopard Change His Spots?
    By Rob in forum Off Topic
    Last Post: 01-29-2002, 05:57 AM
