Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Hooking up multiple amps to Mac Mini
  1. #11
    Newbie RhinoGorilla's Avatar
    Dec 2007
    North Providence
    So this kind of sucks, but would the best bet to keep your car radio for the preamp?
  2. #12
    Jul 2007
    That or use an outboard crossover like this from MTX thats an ebay auction for $30. Nothing from Boss, Autobahn or anything like that unless you enjoy noise being added into your system.
  3. #13
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Quote Originally Posted by RhinoGorilla View Post
    It is certainly one of the options. The other one is to use HQCT which is controlled over USB from the computer.
    I actually got an idea about how to deal with the volume issue, but I do not have time to play around with this now. The idea is not to control the volume of the device, but to apply the volume control as a custom filter on the audio data stream. It will require changes in the application to make it AU-enabled but once this is done, creation of the appropriate filter should be a piece of cake.
  4. #14
    Dec 2007
    North Providence
    Hey Jirka are you working with QCar in Cocoa?
  5. #15
    Newbie ClaZ's Avatar
    Apr 2007
    Turin, Italy
    Audio Hijack Pro.... is perfect for capture the stream audio from any application.
    I use this for change the sound. Not equalizer or other strange things, but for Vacuum tube sound.
    The audio interface that i prefer and use is the RME FireFace 400... nothing else meet this audio object...
  6. #16
    Jul 2005
    Netherlands
    Yes, more or less whole QCar is written in Objective C using Cocoa. AppleScript is used on several places and there are a few shell scripts called from some of the modules.
  7. #17
    Newbie EnglandGreen's Avatar
    Aug 2006
    Houston, Texas
    Edirol UA-1EX - It's from Roland (as in Roland professional synthesizers). It's USB so you bypass the so-so quality "Line Out" earphone jack.
    Add a AudioControl Epicenter and AudioControl Three.1 plus subwoofer amp and up to 2 other amps for front & rear
    The Three.1 gives you a master volume control from the dashboard, as well as subwoofer control, balance and fade.
    See my CarPC specs for details
    EG
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  2. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 04:25 PM
  3. Mac mini hardware/software question
    By lumus in forum General Hardware Discussion
    Last Post: 03-29-2007, 10:03 PM
  4. mac mini core solo enough for bootcamp?
    By replicant in forum MacCar
    Last Post: 06-26-2006, 11:49 PM
  5. Intel Mac Mini on TrailBlazer 2002
    By tizoc in forum Newbie
    Last Post: 04-19-2006, 01:03 PM
