Results 1 to 7 of 7
Thread: Mac Mini hard drive crash
    Sep 2007
    So i had my mac mini in the car for about a month befor ethe hard drive crashed. I new it would one day but never thought it would happen this fast. So how expensive is this to fix and do you think i could bring it to the apple store an pretend like i have no clue what happened. How can i prevent this from happening again cause if theres no for sure way i might as well get a pc in a case.
    Jan 2008
    Western Australia
    hard drives aren't supposed to be in a car, full stop. They just aren't designed for the rough ride... flash memory would be ideal! I guess get another hdd and try again?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    Sounds unusual. I've had mine in and around the car for about two years and had no problems. I haven't seen anyone report this problem either.
    You can probably replace the HDD pretty easily yourself. There are tutorials on the web. Plus, you can speed it up by getting a 5200 rpm drive.
    Want to:
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    Mine failed right about a year after I put it in. I pulled the Y connector for the P1900 out and took it back to the Apple store. They replaced the drive (and also a bad logic board that was giving me issues with the DVD drive) no questions asked.
    Hard drives are finicky things. You could have hit a bad bump at just the wrong time, or you could have just gotten a bum drive (it happens). I wouldn't worry about it too much unless the replacement of your replacement fails too in a very short period of time.
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Jan 2008
    It's not a matter of if a hard drive is going to die but rather when - even if the hard drive is sitting stationary.
    If its not under warranty (used for example) I'd recommend replacing it with a Seagate EE25 series drive - or if you need more capacity just a Seagate. They're generally known as being one of the more reliable hard drives. You cannot beat the 5 year warranty either.
    Sep 2007
    well as I stated I expected it to go just not as fast as it did. Thanks for the replies im going to take it back this weekend.
    Newbie samantech's Avatar
    May 2008
    Solid State HDD are great. I read somewhere that they were first used in Jet fighters. I think 64GB is among the highest and they are still pricy but more durable.
    at aim dot kom
    Pajero/Montero 3500
  1. Boot from a external usb hard drive?
    By DjChrishim in forum Newbie
    Last Post: 12-04-2007, 08:47 AM
  2. 2006 PT Cruiser -Mac Mini
    By zapwizard in forum Worklogs
    Last Post: 11-07-2007, 12:54 PM
  3. Replies: 0
    Last Post: 02-08-2007, 07:47 PM
  4. 2005 Scion xA- Mac Mini
    By Doomspat in forum Worklogs
    Last Post: 11-27-2006, 10:07 AM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
