Results 1 to 10 of 16
Thread: P1900 / Mac Mini weirdness...
    Low Bitrate crimsonaudio's Avatar
    Jan 2008
    Hey guys, I've searched and searched but haven't found anyone with the same issue I'm having here: my P1900 isn't putting my Mini to sleep at all. I can pt the Mini to sleep with the power button when the ignition is on (and it wakes up fine as well), but when I leave it on and switch off the ignition, it stays on (according to the power LED on the front) for about 30-60 seconds then shuts off completely. Likewise, if I put the Mini to sleep then turn off the ignition, it powers down after a minute or so. I double checked the jumpers this AM and they are set correctly (1&2 open, 3&4 closed, 5&6 closed, 7&8 open, 9&10 open) so this must be a P1900 issue, right?
    I'm going to check my battery this afternoon with my DMM, but this vehicle is 6 months old, so I doubt that's the issue...
    Any ideas?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Check System Preferences-->Energy Saver-->"Allow power button to sleep computer".
    Make sure it is checked.
    Want to:
    Jan 2008
    Quote Originally Posted by Bugbyte View Post
    Yep, checked that.
    I've meticulously checked everything. That doesn't mean I haven't missed something, but...
    Any other ideas?
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Is this a new issue or has it been happening from day 1 for you?
    It really sounds like the jumpers aren't configured correctly (or at least that it thinks they aren't). If you are sure they are correct, contact Mike at CarNetix. I found him incredibly helpful when I set mine up.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Jan 2008
    Quote Originally Posted by iamgnat View Post
    Been this way since day 1.
    Yah, after re-reading the manual, it sounds like the jumpers are set for 'hibernate' instead of 'sleep', though I've checked it several times. Guess I'll check that again in the AM. I posted this over on the Carnetix forum as well, we'll see if that gets me anywhere. If that doesn't work, I'll try emailing Mike directly...
    Jan 2008
    OK, tried a couple more things today...
    First, I pulled the dead-man timer jumper, thinking that perhaps a low-voltage situation was occurring just after turning off the vehicle which would cause it shut down as a safety precaution, but that made no difference.
    So then I ran the truck for a few minutes then turned it off, measuring the battery's voltage the whole time. While the truck is running, the alternator is putting out a healthy 14.3V, and when the truck is turned off, the battery's voltage drops (as expected) slowly and smoothly to 12.62V and stays there - never comes close to 10.6 (the cutoff voltage listed in the P1900 manual).
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you are sure the jumpers are set correctly, try disconnecting the power input to the Carnetix for a minute or so. Every now and then it gets screwed up and you have to reset it.
    Want to:
    Jan 2008
    Thanks, but I've already done that several times (every time I mess with the jumpers and such I disconnect it entirely for a few minutes while working on it).
    I'm puzzled.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Have you checked the Macpac wires to make sure it is sending the shutdown signal to the power button?
    Want to:
    Jan 2008
    No, I haven't - any idea what I'm looking for? Is it a pulse?
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  3. Carnetix p1900 and mac mini
    By westcoastrocks in forum Power Supplies
    Last Post: 04-22-2007, 10:03 PM
  4. Mac Mini with P1900
    By johnnyaction314 in forum MacCar
    Last Post: 02-09-2007, 05:23 PM
  5. P1900 alternative power supply for Mac Mini
    By johnsin in forum MacCar
    Last Post: 12-07-2006, 09:05 AM
