Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Applescript?
  1. #11
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    I originally wrote the script to delay 2 because it was trying to click power on jxm before it was open and it was causing an error. Instead i figured a better way would be to check to see if the window was open and if it was then to click it. I wrote this:
    Code:
    set x to 0
    	repeat until x = 1
    		if exists window "JXM" then
    			set x to 1
    			tell process "JXM"
    				tell window "JXM"
    					click checkbox "Power"
    				end tell
    			end tell
    		end if
    	end repeat
    It seems to be getting stuck in a loop though.
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You can also tell your applescript to launch JXM, then save the script as an app and just launch the script. It would open JXM and turn it on for you.
    If you build your applescript as an application in XCode, you can set your own plist values to remember which channel you were last on and so forth.
    Want to:
  3. #13
    Feb 2006
    NJ
    i did tell it to do that....the whole script lauches line in and launches jxm, then hides line in as well as pushes passthru and then pushes power on jxm. That was only a piece of my code. I was just trying to get the computer to check to make sure jxm was open before attemping to power it on. I was running into a problem because it would try and power it on and there was a sliht delay before it was open so i was getting an error. The above code seems to be stuck in a loop though. Thanks again.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If it is stuck in a loop, you probably aren't getting the name of the window right. You may have to use something like "Window 1" instead of "JXM".
    You can print the results of the check (true/false) to the console in XCode but I'm not sure if you can in AS scripter. Maybe record your actions as a script and it will tell you what the name is.
    Want to:
  5. #15
    Feb 2006
    NJ
    you were right the name of the window is wrong, but recording my actions doesnt give me the right name. btw...i pm'ed u...did u get it
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by super-fly View Post
    Yep. Got it and have sent you some stuff. Let me know if it doesn't make it.
    Want to:
  1. Annoucing iKarr
    By jdkarr01 in forum MacCar
    Last Post: 05-14-2009, 08:12 PM
  2. Harmony - Mac Front End Worklog
    By Bugbyte in forum MacCar
    Last Post: 02-23-2007, 12:19 PM
  3. NMEA extraction AppleScript need help
    By zapwizard in forum MacCar
    Last Post: 05-05-2006, 01:10 AM
  4. iDash progress
    By thecapitalizt in forum MacCar
    Last Post: 12-27-2005, 09:39 PM
  5. AppleScript Resorces?
    By iwakura in forum MacCar
    Last Post: 01-22-2005, 07:37 PM
