Results 1 to 9 of 9
Thread: Mac Mini Sound Card Opinions?
    Jan 2008
    Santa Barbara, CA
    Hey I just hooked up a mac mini and a Lilliput 7" 619 in my car last night. I got a JL Audio 450/4 amp and have 2 12"'s on the way. Want to see what you guys thought would be the ideal software or sound card (internal/external?) to pump out best sound. Thanks.
    Variable Bitrate Area3's Avatar
    Mar 2007
    Garland, Texas, United States
    What Front End Will You be Using?
    I am planning a Mac Mini Install In My Car and This is the Sound Card I am Going With...
    2 x 8 24-bit/96kHz analog I/O; 192kHz stereo out
    2 mic/line ins w/ preamps and phantom power
    8 line outs to mixer or direct surround output
    S/PDIF digital I/O w/ PCM, AC-3, and DTS support
    1 x 1 MIDI I/O
    includes Ableton Live Lite music production software, so you can make music right away
    http://www.m-audio.com/products/en_u...e410-main.html
    Any More Questions Just Ask!
    Microsoft Is a Evil Empire that has corrupted a generation!
    Thanks - Eric Scott
    Area 3 Productions
    www.myspace.com/area3
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Ahhhh, the M-Audio firewire 410, she is lovely isn't she?
    Jul 2007
    ive had a mini in my car for a year now and im not convinced im using my speakers and sub to their potential. ive got 2 rear and 2 front JBLs and a JBL sub connected to a 6 channel JL amp. the amp connects to the mini through the headphone jack. will the 410 help get a better sound to the amp? sell me on it
    Jun 2007
    Well, the Firewire 410 is ASIO plug-in compliant, so you can use software to do tuning. From 31 band eqs on every channel to phase control to time alignment to crossovers.
    A little more on ASIO:
    ASIO: (Audio Stream Input Output) is a protocol for low-latency digital audio specified by Steinberg.
    ASIO provides an interface between an application and the sound card. Whereas Microsoft's DirectSound is typically for stereo input and output for consumers, ASIO provides for the needs of musicians and sound engineers. ASIO offers a relatively simple way of accessing multiple audio inputs and outputs independently. It also provides for the synchronization of input with output in a way that is not possible with DirectSound, allowing recording studios to process their audio via software on the computer instead of using thousands of dollars worth of separate equipment. Its main strength relies in its method of bypassing the inherently high latency of operating system audio mixing kernels, allowing direct, high speed communication with audio hardware.
    Mar 2007
    Quote Originally Posted by Machinehead View Post
    Shes Ok Nothing Like my SSL at Work
    But yes You can use this for Tuning and Stuff!
    Thanks - Eric Scott
    Area 3 Productions
    Apr 2007
    I went low tech. At first I ran the headphone out directly to the amp, but couldn't get the quality of volume control I needed. Eventually, I re-installed my CD player (Apline CDA-9856 w/ external input and 3 sets of pre-amp outputs). Works excellent now, and even allows friends to plug in their iPod via the Alpine AiNet iPod cable.
    if you have space for a head unit, go that route, just make sure it has external inputs in the back. I drive an xB so dash space is not an issue.
    Newbie samantech's Avatar
    May 2008
    There are some decent sound cards out there and some are expensive.
    Duet
    http://www.apogeedigital.com/product...?section=specs
    Audio Kontrol 1
    http://www.native-instruments.com/in...=audiokontrol1
    Though I have not tested them in car environment to withstand elements.
    Samantec
    at aim dot kom
    Pajero/Montero 3500
    Low Bitrate sonneboz's Avatar
    Jan 2008
    Tampa
    I just picked up this fancy little DAC, haven't hooked it up yet, but sound quality should be very good
    http://www.mp3car.com/vbulletin/gene...bloat-dac.html
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  2. Replies: 4
    Last Post: 03-22-2007, 09:15 AM
  3. Recommended Sound Card - 4 Channel/5.1
    By efficinet in forum Road Runner
    Last Post: 02-23-2007, 01:49 PM
  4. Mac Mini questions, possible FAQ
    By metalac in forum MacCar
    Last Post: 09-11-2006, 09:37 AM
  5. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 08:18 AM
