Results 1 to 10 of 13
Thread: Speeding up boot times - EFI
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I've noticed that my Mac Mini takes over 30 seconds from power on to start of OS boot. During this time, my display is white and it's my assumption is that the BIOS (EFI) is prepping for OS boot.
    Does anyone know of a way to adjust the EFI settings to speed this process up?
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    no but if you hold down command + v (i think) at boot time it will boot in verbose mode so you can see what is taking so long
    check us out at: www.neonboombox.com
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    That depends on where in the boot cycle it is hanging as I believe that verbose mode only applies once booting has been handed off to the OS (though I could be wrong as I rarely use verbose mode).
    When you say you have a white screen, do you mean the light grey with the Apple logo or something else? If it is prior to the Apple logo, then there is likely some bad hardware causing the issue. If that is the case, i'd suggest bringing it in the house and running some diagnostics on it to see if you can find the culprit (could be your drive, it's controller, the mother board, bad RAM, or something else seemingly unrelated that the EFI tests at boot).
    Apple support will probably be your best bet if you still have AppleCare on it.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
    Jun 2007
    Well, it's a mac mini so it's probably the light gray screen you mentioned. The Apple logo doesn't come up until OSX starts booting.
    I wouldn't think it's bad hardware since everything works, but it does sit there for a good 30 seconds on average. Which if that's normal for a mac mini, then it is what it is.
    Feb 2008
    verbose mode does away with any of the mentioned screens. it is black background with white text the whole way. I'd seriously check it to see what it says
    also. since you didn't mention it this is an intel I am assuming since G4s don't have EFI. you seem to know what you are talking about so I'm guessing its not a G4
    I'd actually wager it has something to do with a network interface. In my experience with slow boot times anyway
    Jul 2004
    NoVA
    Quote Originally Posted by Machinehead View Post
    Bad is a relative term. It could be a piece of hardware that you don't regularly use (but is tested at boot) or it could be something responding slower based on the usage pattern that the boot operation utilizes (e.g. maybe the blocks where the XNU kernel are located are going bad and throwing read errors while (most of) the rest of your drive is just fine).
    Another item that is possible is fsck. If it believes that your disk structure is "dirty" (typically after power loss or a hard crash), the OS will run fsck on the disks before proceeding with booting and is somewhat normal and can take some time. If it is doing a fsck, that should show up in verbose mode. If it is doing a fsck every time, even if you shutdown/reboot cleanly, then that can also be indicative of a drive going bad.
    I've never timed it (cause it hasn't been slow enough to care), but at a guess i'd say my CoreSolo boots in around 15 seconds give or take a few. I don't think 30 is unreasonable, but if this is a new phenomenon for you then it is indicative of something changing.
    -dave
    Feb 2008
    ha ha I was just coming back to post about the fsck. you beat me. I'm almost positive tho that if there is a problem it will show up in a verbose boot
    Jun 2007
    Does bootcamp have any effect on the boot time?
    I wouldn't say the 30 second time is a new phenomenon, but as I'm looking to shorten my cold boot times (long story but I have hardware that don't like sleep), almost half of my boot time right now is waiting for the bios (EFI) to turn over to the OS Boot.
    Quote Originally Posted by iamgnat View Post
    That's a possibility since sometimes my system doesn't completely shut down before the power is cut.
    Feb 2008
    you haven't said how you are certain that this problem is EFI related... I'm curious as to how you are able to come to that conclusion. sounds like if your system isn't being shutdown properly it is a combination of fsck and out of date boot caches
    Jun 2007
    I properly shut down my system this morning, so the EFI time was approximately 12 seconds when I left the office this afternoon. A lot better than it was on my last boot. Looks like that solves that problem. You and Dave had me worried that my hard drive was failing already. Thanks for the information.
  1. Slow Boot times after TinyXP
    By Grrrmachine in forum WinNT Based
    Last Post: 11-03-2007, 04:40 AM
  2. Survey: Startup times and methods
    By gnomad in forum General MP3Car Discussion
    Last Post: 01-02-2007, 12:55 PM
  3. boot times with XP
    By Alives in forum General Hardware Discussion
    Last Post: 11-15-2001, 01:42 PM
  4. boot times
    By pinkysqueaks in forum General MP3Car Discussion
    Last Post: 08-31-2001, 07:30 PM
  5. boot times for mp3 players
    By alany in forum General Hardware Discussion
    Last Post: 12-16-1999, 01:09 AM
