Results 1 to 5 of 5
Thread: Need help
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    Need help
    My car is going to be in a small car show at school tomorrow, my dilemma is leaving the compter on without running the battery dead. My though would be to hook a battery charger to the battery to keep it charged. My question is what type of settings should I put the charger on? I believe there are three options, all 12V with varying current: jumpstart(which assume I would not use), quick charge, and trickle charge. Any thoughts as to which setting would work to keep everything going without the battery dieing? Thanks.
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    I would assume 12V. isn't that the voltage that the alternator puts out when the car is running? the only other option that looks any good to me is trickle.
    I suggest posting this question in another forum also if you haven't already since it is not mac specific.
    check us out at: www.neonboombox.com
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Use trickle and keep an eye on the voltage. If it drops too much, use quick charge.
    Want to:
    Feb 2006
    NJ
    what should it be at....at least 10V?
    Constant Bitrate onepuff's Avatar
    Jan 2006
    Yea at least 1ov. The quick charge setting will just put out a little more amps than trickle. The mini doesn't use much juice so as long as your sound system isn't drawing too many amps trickle should work fine.
