Results 21 to 30 of 38
Thread: Road Runner
  1. #21
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by greatwhite View Post
    You also have to make sure that the .dll for winamp is registered (it's in the RR file).
    RRconfig is supposed to take care of that.
  2. #22
    Jun 2007
    Quote Originally Posted by super-fly View Post
    has anyone running road runner found a way to get the itunes album art to show up. I able to access my itunes library through the shared folder but would like to get the album art to show up also.
    What format is the itunes album art in?
    The default RRconfig setting has RR look for folder.jpg in the album's folder.
  3. #23
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Quote Originally Posted by Machinehead View Post
    Yeah, I know. I think you mean the installer though, not config.
    But I had to do it manually last install with the latest RR.
    Dunno, maybe something didn't register properly.
    But you guys are using it on a mac. There may be several problems that haven't shown up in regular pc usage that you might run up against.
    If it's embeded in the music file or the AA is in "hidden" format, RR won't display it.
    At least, doesn't for me.............
    Leonardo Da Vinci
  4. #24
    Jun 2007
    I had the same problem initially as well, since I ripped all my CDs using WMP which makes all the album art invisible.
  5. #25
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    itunes uses a proprietary file format for its album artwork. this means that only itunes can use it. i dont know for sure, but i don't think RR has a way of reading the itunes album artwork. there are some programs out there that will strip the "special" itunes album artwork file and saving it as a jpg. NAS has that functionality built into it. but then again i don't know for sure how RR has to have its album artwork to be able to display it. i could be wrong all together.
  6. #26
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    I have this weird white bar on the main screen, I searched over in the LSX Void post and apparently updating flash player is suppose to fix it. However I did that and its didn’t, I also checked to see if the compass was disabled, it was. When I enable it a compass bar shows up instead of the white. I’d like there to just be nothing there. Anyone else with road runner installed have this problem. I don’t have internet explorer installed which was what the flash player upgrade I download was for, is this a problem? Thanks
  7. #27
    Feb 2006
    NJ
    I got a script that converts all the album art to jpg and puts it in it's respective folder. I got the album art showing up in the library of road runner, only it doesn't show up on the main screen when a song is playing. I'm going to post over on that forum to see if they have any answers. Also, after using road runner for a little while and trying to figure out how things work, I've come to apreciate Amp a lot more, road runner (maybe the skin I'm using) just doesnt seem very intuative to me. I just wish development would hav continued on it. If there was a XM integration and some way to integrate iGuidance through fusion in it that would be nearly the perfect solution to me. The only thing lacking that I could deal without is bluephone elite integration and obdII. It looks like Neon Boom Box has promise though and I have high hopes for it.
  8. #28
    Jun 2007
    I have this weird white bar on the main screen, I searched over in the LSX Void post and apparently updating flash player is suppose to fix it. However I did that and its didnít, I also checked to see if the compass was disabled, it was. When I enable it a compass bar shows up instead of the white. Iíd like there to just be nothing there. Anyone else with road runner installed have this problem. I donít have internet explorer installed which was what the flash player upgrade I download was for, is this a problem? Thanks
    If the compass works, then I would assume it's supposed to have that white bar, but I haven't used that skin very much to know.
    You may want to just edit the skin and take the compass out all together.
  9. #29
    Feb 2006
    NJ
    It's suppose to look like the top, but it looks like the bottom one.
  10. #30
    Jun 2007
    Your fonts look screwed up too, that's why you're getting the 7,4,8 rather than back, play/pause and forward. And the plus/minus volume buttons are wrong too.
    Edit; The easiest way to fix it is to reinstall the skin.
  1. Replies: 15
    Last Post: 09-22-2008, 08:02 AM
  2. PhoneControl integration w. Road Runner problem
    By Broendbjerg in forum PhoneControl
    Last Post: 11-05-2007, 11:01 AM
  3. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 01:58 PM
  4. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 09:50 AM
  5. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 02:16 AM
