Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Road Runner
  1. #31
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    Yeah sorry...i just took that picture from a different thread as an example. All my buttons are good except for that white bar. I will try and reinstall though. Thanks.
  2. #32
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    The white bar is a flash problem as that is a flash compass.
    BUt it should be simply transparent if you have it turned off and it works when you have it turned on.
    As I said in the void thread, it might be becuase you're runnig it on a MAC.
    Have a look through your config to make sure it is done properly.
    Worst case? Open void with the RR skin editor and remove the flash coded area.
    Good luck.
    Leonardo Da Vinci
  3. #33
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    It's not that he's running it on a mac, I don't have that problem on my mac. The problem maybe that he's using VMware Fusion rather than bootcamp.
  4. #34
    Feb 2006
    NJ
    I actually figured it out guys, thanks for your help. I think its cause I used nLite. I found a standalone flash/ActiveX installer and it fixed it. I'm now just trying to figure out how everything works. I just wish there were some sort of txt doc or something; it's not very intuitive. The album art is still not working on the main screen, however I just chose not to display and to display a large logo instead. Is there any way to get rid of buttons. There are way more than I want. I think a lot of them require an internet connection. Like gas and what not. I was trying to figure out what freefone is last night and how I actually connect to it with no luck.
  5. #35
    Jun 2007
    Well, there are 2 options, one is to change the buttons to that they link to what you actually will use. Which I don't know how to do in LSX Void. The other option is edit the skin files and remove buttons.
  6. #36
    May 2007
    Quote Originally Posted by Machinehead View Post
    Press and hold brings up a menu, you can then selet from preprogrammed buttons or define a custom action by embedding a program.
    Or edit the skin.
    Leonardo Da Vinci
  7. #37
    Jun 2007
    Quote Originally Posted by greatwhite View Post
    Same as DFX then.
  8. #38
    Feb 2006
    NJ
    i wrote a simple script that will launch XP, close the library window and hide the xp window. If anyone wants it let me know. It could also be modified to launch unity mode, or to launch something like road runner. That way you could add it to you startup items and it will launch say road runner at startup.
  1. Replies: 15
    Last Post: 09-22-2008, 09:02 AM
  2. PhoneControl integration w. Road Runner problem
    By Broendbjerg in forum PhoneControl
    Last Post: 11-05-2007, 12:01 PM
  3. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  4. Road runner Ideas (BIG LIST)
    By sephiroth7 in forum Road Runner
    Last Post: 04-01-2007, 10:50 AM
  5. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
