Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: XP boot time on Mac Mini
    Apr 2007
    I have an Intel Mac Mini 1.86Ghz w/XP running via bootcamp. It taks about 90 seconds to fully boot into my front end app, and about 55 seconds to resume from hibernation. I have disabled all unneeded services in XP. I will probably do the minlogon route to see if that speeds anything up.
    What are your XP boot times?
    Would a clean XP install with no OSX speed it up?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I've gotten it down to 50 seconds for a cold boot and about 30 for hibernation. Minlogon doesn't really help much, it may save you a few seconds. I'm recommend getting TuneXP (Link:http://www.download.com/TuneXP/3000-...-10290929.html) and running the ultra-fast boot option. It essentially defrags and moves the critical boot files around to optimize boot times. Download and run bootvis and have it optimize your boot up.
    Also disable any hardware that you aren't using, like the wired ethernet, bluetooth, wifi, etc.
    Probably the biggest slowdown on the Mini is the 10+ seconds it takes to get out of the bios and start the OS boot process.
    Apr 2007
    Quote Originally Posted by Machinehead View Post
    Thanks -- I have disabled wired ethernet, but using bluetooth so I can't do that.
    From what I read on microsoft site XP sp2 already uses bootvis or bootvis logic -- have you actually used it or TuneXP?
    Jun 2007
    I've used both, TuneXP's Ultra-fast boot option had a noticeable effect on boot time for me.
    Another thing to look into is nlite to create a stripped down version of windows. There are some versions of windows floating around already pre-stripped like TinyXP, although technically it's illegal.
    Edit: Also turning off the paging file will save you another few seconds of boot time as well.
    Apr 2007
    Yeah I have looked into TinyXP... was kind of waiting to complete my hardware installs before I went further. Think that's now actually. Just ran the boot optimizations and a couple others from TuneXP. No impact at all on cold boot time or resume. Oh well.
    btw my times included loading my front end app.... so time to usefulness ithe car. I can live with it, but will keep trying.
    Jun 2007
    What are you running as front end? I'm using RoadRunner, it only adds about 5 seconds.
    Apr 2007
    yep roadrunner w/DFx skin.... it doesn't take long... but resume hangs until I touch the screen for some reason... maybe the logging from bootvis will help figure out what's happening. Hibernate works fine, but takes way too long to resume.
    Are you using dual boot w/bootcamp or did you install just XP? I assume an XP only install still uses the "virtual bios"
    Jun 2007
    Cold boot has a lot less issues than resuming from hibernate, at least from my experience.
    I'm just using XP, OSX is a waste of space for me. And yes it still uses the virtual bios, otherwise known as EFI.
    Variable Bitrate NeonDev's Avatar
    Feb 2008
    a mini has no BIOS chip so yes XP only still has to use the BIOS emulation supplied by the EFI
    EDIT: Machinehead you beat me!
    check us out at: www.neonboombox.com
    Apr 2007
    Ok so for the moment I'm going to be lazy and keep asking (rather than searching). I originally installed OSX/bootcamp and XP both because I was going to experiment with which I liked better.... but now...I'm going to stick with windows since what I want it to do is working great (except for boot time). Can I remove OSX, and re-size windows partition without doing a total re-install? I tried using... oh I forget.. some windows partition tool and it wouldn't let me re-size the OSX partition.
    Related question.... is the XP only install a different boot process than bootcamp?
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 11:16 PM
  2. Full XP on USB,someone tryed this?
    By gradecak in forum Software & Software Development
    Last Post: 03-20-2008, 07:36 AM
  3. War Driving on XP intel mac mini?
    By KryptonianJorel in forum Wireless Communications
    Last Post: 10-23-2007, 06:54 PM
  4. 2005 Scion xA- Mac Mini
    By Doomspat in forum Worklogs
    Last Post: 11-27-2006, 11:07 AM
  5. 1.0.4.7 bug
    By debugger in forum StreetDeck
    Last Post: 07-01-2006, 04:01 AM
