Results 1 to 10 of 10
Thread: mac mini and usb devices
    Apr 2007
    i'm running XP on a Mac Mini with the follow devices connected to the 4 USB ports
    1. Emu 0202 External Sound
    2. Touchscreen
    3. Matrox DualHead2Go VGA splitter
    4. USB mouse
    When I plug out the USB mouse and try to power up a USB hub, it turns on. However, no devices are able to work within the hub, including the USB mouse. Am I short on power?
    I'm currently using the P1900. Will adding a 5V supply solve my problem since I'm suspecting my USB bus is overloaded with the 3 devices mentioned.
    Pls advice.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That sounds like the problem. When you plug just one device into the hub, does it work? If so, try two. If that works, try three and so on.
    Try them in different orders in case they draw a lot of power. If any of them work when plugged into the hub alone, that is most likely the problem.
    Want to:
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    If it is a power issue the 5v supply add-on will solve that problem.
    Apr 2007
    nothing works in the hub.
    when i plug out the hub and put a usb mouse instead, it works.
    am i not getting enuff power? the hub works as expected on my macbookpro with no other usb devices
    cheers
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well...THERE's yer problem! Don't know why it is finicky but sounds like the hub.
    Want to:
    Apr 2007
    does that means the additional 5v supply for my p1900 shd solve the issue?
    another piece of advice i need. is it possible to split the 12v secondary voltage to 2 lcds?
    else what's the best method to power up
    1. mac mini
    2. 7" lcd
    3 10" lcd
    4. 5v powered usb hub
    is getting 2 p1900 the only way to go?
    thanks
    Jun 2007
    Test the hub with it plugged in to the wall. That will tell you if that's the problem.
    You can power a second LCD off a cigarette lighter adapter rather than spend money on a second p1900. Radio Shack makes adapters you can hide behind the dash.
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    You can just split the power from the P1900 to two screens. My calculations show that there's power left over after my mini and my screen. You'd have to find out how much power your USB hub needs to determine if you can power the second screen.
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
    Apr 2007
    you mean splitting the secondary output to power 2 LCDs? Is that possible?
    i'll be getting the 5V add on regulator for the usb hub
    Nov 2006
    Fort Worth, TX
    Yes, it's possible. Check your screens for power dissipation specs. Carnetix says the secondary output is good for 15 watts or 1.3 amps at 12v. If your two screens use less than 15 watts, you will have no problem powering both of them from a single output. All Xenarc screens on their company site are specified at <8 Watts. Lilliputs are speced a little higher. These are peak power demands and not steady-state dissipation. The Carnetix manual states that the P1900 is protected from overcurrent by automatic shutdown and will not be damaged if you overload the 12v output. So you can try it without worrying about killing your power supply. If it works, you're good, if not, you can run one of them from the included 12v car adapter, except you won't get the auto power-off.
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  3. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 10:16 PM
  4. Powering a USB Hub with a mac mini + P1900
    By BGH in forum Power Supplies
    Last Post: 06-25-2008, 02:27 AM
  5. Replies: 7
    Last Post: 04-18-2005, 12:41 PM
