Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: Draining Battery
  1. #21
    Jan 2008
    Dartmouth, MA
    Most multimeters out there measure both AC and DC amps and do so in separate modes on the multimeter. Make sure you are on the DC mode.
    The symbol for AC is a sine wave and this is the symbol for DC: [media]http://upload.wikimedia.org/wikipedia/commons/thumb/2/20/DC_Symbol.svg/120px-DC_Symbol.svg.png[/media]
    Once you set it properly, you should be good to go.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  2. #22
    Jan 2008
    My multimeter is autosensing - and I even set it manually to DC, but still reading zero - which I know isn't right...
  3. #23
    Jan 2008
    Dartmouth, MA
    I'm assuming there are 3 connectors on the multimeter... 1 com (common ground) and two possible places for the positive wire. Try the positive wire in the other spot.
  4. #24
    Jan 2008
    Yep, you're right. One is Unfused 10amp, the other a fused 0.5amp. Neither work.
    Perhaps my multimeter is busted, as far as the ammeter side goes? I'll try to find someone else around that has one I can borrow.
  5. #25
    Jan 2008
    I ordered a CNX-P5V and plan on covering the +5V pin on the USB cable so USB devices only draw from the P1900.
    With this set up though, once the computer goes to sleep - won't the loss of power to the P5V (and the USB hub/devices) cause the Mini to wake up again?
  6. #26
    Dec 2008
    Quote Originally Posted by PaulF View Post
    To test current draw, you have to hookup the equipment through the multimeter. So hookup the equipment's positive wire to the positive on the power source and then hook up the equipment's negative wire to the positive on the multimeter and then the multimeter's negative back to the negative on the power source.
    Check how many amps the multimeter is rated for. I have one from radio shack that is fused at .5 amps so you really can't do much with that you might be able to take out the fuse and put a piece of metal across the fuse contacts temporarily to measure this, but don't do this for more than a couple of minutes or else you risk fire.
    Not sure if understand the logic behind the ammeter and its fuse.
    You will need to connect the circuit and ammeter in series. If you want to do it from the car battery, disconnect one of the terminals, then use your ammeter like a piece of wire to connect the battery terminal and the lead.
    Basically, the ammeter has negligible resistance, so it will not affect your circuit at all. If you have tried to measure the current by doing it in parallel, meaning like how you measure voltage, alot of current will flow through, as I = V / R, since V = 12V (car battery) and R is very very small, I is very very large, and it will most likely fry the fuse in the ammeter. Subsequent correct measurements will come out to be zero as the fuse is gone and there is infinite resistance, so no current will flow through.
    As for the AC and DC, some multimeters will only have signs to say, a ~ sign means AC, DC is an unbroken line above a dotted line (you need the DC one).
    How about disconnecting your entire setup for 1 day, and see if it is really the cause. A simple short or near short somewhere could be the problem too.
  7. #27
    CarFrontEnd Creator iamgnat's Avatar
    Jul 2004
    NoVA
    Quote Originally Posted by fone View Post
    The logic is that on Ammeters that have fuses, they are A) meant for in-circuit work and B) their electronics and/or leads are not rated to handle a current higher than the fuse.
    What you really need for this kind of work is one that clamps over the power line and isn't in-circuit. I have one from Craftsman that I just picked up to deal with my own power issues.
    -dave
    My pathetic worklog.
    CarFrontEnd (now it's own sub-forum!!!!)
  8. #28
    QCar Creator Jirka Jirout's Avatar
    Jul 2005
    Netherlands
    Just to make sure: not all clamp ammeters can handle DC! The cheaper ones only handle AC (a normal induction I guess), while the more expensive ones can handle both AC and DC (using a Hall-effect sensor).
    They are also nowhere close to the regular ammeters when it comes to precision of measurement - most of the Hall-effect-based ammeters need to be calibrated more or less before each measurement to compensate for Earth's magnetic field.
    If your battery lasts for a few hours while parking, use a clamp meter. If you are hunting down some tens or hunderds of mA, use a regular multimeter instead.
  9. #29
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    Quote Originally Posted by TTeuer View Post
    It probably uses the same sequencing for the shutoff that it does with the +12V. The P1900 first shuts down the +12V (i.e. touchscreen with USB) and then the +18V for the computer, so that USB transients from the screen will not wake the computer. Check the manual, but I imagine it uses the same for +5V.
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  10. #30
    Low Bitrate Salmizar's Avatar
    Oct 2007
    Ontario, Canada
    Quote Originally Posted by Bugbyte View Post
    Jirka's method of covering up the +5 volt pin is the slickest method I've seen. You just cut a very small sliver of tape and place it over the +5v contact on the connector. Then, plug it in and it won't draw power from the Mini.
    I've been using a special USB hub that mp3car is developing for solving this exact problem. Not available yet, but I've been testing it. Until then, I used an unpowered hub.
    Again, you can use Jirka's tape trick, or open up and actually cut the 5V line on a spare USB cable. If you want to preserve the possibility to draw from the computer, put a switch on that line and enclose it in one of those radio shack project boxes.
    What model of USB hub are you using to accomplish this? I tried the 'covering the 5v lead' method but it would cause my hub not to be recognized after standby, and cause the computer to crash if then pulled to reset. so I had to revert back.
    Any idea when this hub will be available? I have bought a few relayed and I am debating making my own usb switch to cut the power off when in standby, but would rather have it all into one built in unit.
  1. Replies: 4
    Last Post: 08-15-2006, 08:20 PM
  2. Battery draining while car sits
    By schapman43 in forum Power Supplies
    Last Post: 07-14-2005, 12:33 AM
  3. Replaced Motherboard battery now no post??
    By BADDERICK in forum General Hardware Discussion
    Last Post: 07-08-2005, 02:34 PM
  4. Battery an Alternator
    By UM_Fan in forum General MP3Car Discussion
    Last Post: 07-07-2005, 06:45 PM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 09:31 PM
