Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: horrible computer noise through speakers
  1. #11
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    Quote Originally Posted by Bugbyte View Post
    You are definitely picking up electrical signals from inside the Mini.
    If you are using an iMic, then the signal is digital all the way down to the iMic connection. Try using a USB extension cable out of the back of the Mini and a short and well shielded (i.e. high quality) 1/8 cable to the amp, well away from the Mini.
    that is a good suggestion. i did try using a usb extension cable to get the imic away from the mini. however i am using a somewhat long 1/8 to rca cable. this did not help at all, but i may try getting a higher quality 1/8 cable however this all turns out
    Check out the new version of NAS, a cross platform music frontend here
  2. #12
    Jan 2007
    Dallas
    ok here are some pics of my setup. sorry if the quality is poor, i took these with my iphone this morning before work.
  3. #13
    Constant Bitrate onepuff's Avatar
    Jan 2006
    Well i would try isolating the mini from the carnetix. Also have you just plugged in a set of headphones to the iMic output to see if that eliminates the noise. Just try to rule out each element one at a time.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Well, there's your problem! PSU too close to Mini. Move it far away.
    Want to:
  5. #15
    Jan 2007
    Dallas
    hmm very interesting. i will have to try that tonight. i have pulled my mini out of the glovebox while it was running, with no difference, but maybe if i pull the psu out and mount it somewhere far awayfrom all the sound cables that might be the key. Thanks
    onepuff: that is a very good idea. i will try that as well
    one more question. do you think all the components should share the same ground?
  6. #16
    Jan 2007
    Dallas
    alright so we have some more information that is making me start to think that this is never going to be fixed. so i followed bugbyte's advice about moving the psu away from the mini. ok so i tried that. i moved the mini out of the glove box onto my center console (for testing purposes only of course) and the moved the psu as far away from anything that had to do with anything related to sound. fired it all up and im not sure but it may have made things worse.
    so after that i tried onepuff's advice of testing each component separately. i came to the conlcusion that it is not any one component by itself that is causing the noise. it has to be all of the components once they are connected together. there has to be some sort of grounding issue or something. i don't know i am really running out of ideas here.
  7. #17
    Constant Bitrate avengerki's Avatar
    Mar 2006
    Oregon
    Have you tried adding capacitors inline to your audio cables.
    Avengerki
    PC Install: 85%
    Car PC: Revo-Sys X300 Double Din: 1.3GHz Pentium
    Software install and setup: 35%
    Entertainment Package: 85%
  8. #18
    Jan 2007
    Dallas
    Quote Originally Posted by avengerki View Post
    no i haven't. i don't think that this is the issue. the more that i research and the more that i test i keep coming to the conclusion that something is off with the way the power is being run/ grounded. for the past hour i did some intensive google searches on just general system noise. for the most part i knew that i would be reading about how to get rid of alternator noise, but i figured that they may have some general tips about overall installation that would reduce or prevent any kind of noise getting into the system. one thing they all say is to steer clear of the ground that is coming through the factory wiring harness. this is something that i did not know. in fact every one of my components are connect to that ground! also they said to ground each component to its own spot on the chassis of the car. once again all grounds were going to the same spot. so as i am writing this i am trying to figure out where i can find these grounds. i am about to go do some more testing and i will report back with what i find. Once again thanks for everybody's ideas and suggestions. please keep them coming, because this very well maybe another dead end.
  9. #19
    Jun 2008
    MA
    My onboard audio card was sending a very loud hiss at high volumes. In an unrelated fix, I changed the case fan (which was running off the MB) and the hiss went away. What does this mean? Beats me, but I would try to isolate the problem: first try the computer with some regular computer speakers, if there is hiss you know where your problem is.. Try taking it apart and removing components (like fans hehe) one at a time.. the mainboard could just suck that way.. If it works well with speakers at least you'll know for sure it's the amps or wiring.
  10. #20
    Jan 2006
    So you still had the noise with the headphones? Did you try it without the iMic just the headphones? Have you tested it out in the house? Have you ever opened up the case? I'm assuming you did if you have the y-cable hooked up for the carnetix. Might try opening it up again and see if something has come loose inside. When i added RAM to mine a screw came loose and was rattling around inside causing it to shut down every so often.
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
  3. Noise over my speakers
    By z8man in forum Car Audio
    Last Post: 09-21-2006, 08:05 AM
  4. weird noise in speakers....HELP
    By chadcj7 in forum General Hardware Discussion
    Last Post: 01-16-2006, 06:19 PM
  5. Noise coming through speakers - Help Needed
    Last Post: 09-27-2004, 04:31 PM
