Results 1 to 10 of 11
Thread: Powerbook G4 power?
    May 2009
    Powerbook G4 power?
    Hello all,
    I'm setting up my powerbook (G4 12" 1.5 GHz) for use in the car. it'll be pretty much the guts put in a different case (the display broke on me) to make it smaller.
    I was wondering if it was possible to power the computer through a standard intelligent automotive atx power supply, obviously bypassing the original DC-DC board.
    Thanks!
    Josh
    Elsewhere
    Laptops aren't ATX-compliant, so you can't use it the way it was meant to be used.
    IF the power prick outputs 12vDC, you could use an ATX unit to output the 12v, but it's a kluugey solution. I wouldn't recommend it, but others have done it.
    Check the output voltage of the power brick. Its likely the necessary voltage can be provided by one of the Carnetix regulators.
    And here's a good read for you: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
    How about the Wiki?
    May 2009
    my charger puts out 24Vdc @ 2.7A ==> 65W
    So, no dice for the carnetix supplies...
    I guess i'll be looking out for a cigarette lighter charger.
    Elsewhere
    The ATX PSU's couldn't put out the 24vDC you need, either, so that's out as well.
    A cig lighter power adapter can be hardw-wired to the car, so that's an option.
    How about the Wiki?
    May 2009
    yea, i figured that's the best way to go, and wire an interrupt switch in the cig lighter.
    (it's not switched) should I use a relay for that, or can i just cut the positive wire and run it through a switch?
    Elsewhere
    If you wire it to an ignition-controlled circuit (or use a relay controlled by ignition), you don't need a switch at all. A turn of the ignition key is your switch.
    If the Powerbook has an option to boot when it receives power, then you're set.
    How about the Wiki?
    May 2009
    the current going through a 12Vdc relay should be negligible right?
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    have you checked if apple makes a car charger?
    May 2009
    no they don't, but these guys do. I'm thinking about just ordering that.
    duh forgot link...
    http://macwizards.com/store/product_...products_id=32
    Mar 2005
    Rockledge, FL
    there you go, just use that, but i would hard wire it though, if you don't want to cut your brand new adapter you can hard wire the end of one of these and connect the other end to the adapter
    http://www.radioshack.com/product/in...ductId=2062266
  1. HOWTO: Power a USB Hub for the G4
    By god_of_cpu in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 06-05-2010, 10:17 PM
  2. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  3. Replies: 0
    Last Post: 01-16-2009, 11:48 PM
  4. Power specs of the G4?
    By drakino in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 08-21-2007, 07:36 AM
