Results 1 to 10 of 12
Thread: How to mount the Mac Mini in a Single-DIN slot?
    Nov 2007
    Has anyone done this before? If so, what did you use? I can't seem to find a mounting bracket for the Mini that will allow me to screw it into the factory bracket. If I can't find anything, my "plan B" is to gut an old car radio and install the Mini in there (since the casing has all the right holes already), but I would rather not do this if there is a prebuilt (or otherwise better) option available.
    Thanks!
    Jan 2008
    i seem to remember reading that bugbyte created his own mouting solution for this, and other than the dd monitor kit that mp3 car sells with the monitor, i have not seen any other computer-in-dash mounting solutions.
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    yeah i have never seen a mounting bracket for the mini either. it wouldn't be to terribly difficult to make one though. just remember that whatever route you go to make/get a bracket, make sure there is enough room under the mini for it to get sufficient ventilation.
    Check out the new version of NAS, a cross platform music frontend here
    Nov 2007
    Quote Originally Posted by soundman98 View Post
    I found BugByte's worklog, and unfortunately, the links to the pictures no longer work From the text, I can make out what he did, but he's trying to make the Mini able to be easily removed. I don't really need that sort of functionality, so I'll likely go with my Mini-in-a-gutted-radio idea. It's more secure that way as well (I'll bolt it down).
    Thank you for the tip though!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Right, I made a removable dock from plexiglass. The Mini slid into the dock and the connectors are at the back end.
    It would be much easier to make it a permanent install.
    The issue that you will have is the amount of room at the back end of the Mini. The connectors stick out quite a bit, particularly the video connector. You may have to do some home-made cable building. That's what I had to do to get the HDMI to VGA to work.
    If I had it to do over, I'd have gone with a right angle HDMI connector and put the VGA adaptor at the end of the cable.
    Want to:
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Here's some pics of it.
    Want to:
    Nov 2007
    Fortunately, in this section of the car I have several inches of room, so I'll likely be able to use the DVI->VGA adapter from my old PBG4 (the kind with the cord in the middle). My main issue is securing the Mini, because it has to be able to attach to the mounting brackets, as there's nothing it can really be sitting on. I just want it to be as secure as possible. I may even add a CD-player faceplate so it looks like a $100 CD player instead of a $400 Mac Mini.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Inspired by Bugbyte's mount, I made a plexi box to hold my mini. It's just snug enough that the mini doesn't move, but it's still removable for maintenance. I wish I epoxied the cables like bugbyte did to make it easier to put back together.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Okay, in order to remove the Mini from the dash, I actually built and attached a lunchbox style handle to the front.
    Using a drill and a tap, I put threaded holes in the side of the Mini to attach the handle. I used threadlock to keep them from screwing in too far or from falling out. That has worked perfectly.
    You can do the same thing with your Mini. Figure out where the holes are inside the dash and transfer the markings to the side of the Mini. Pop the computer guts out, drill and tap the holes, and it will mount straight in with screws just like a regular head unit.
    Sure, drilling holes in the side of your pristine Mini sounds harsh, but you're about to put it into your dash. Nobody cares and nobody will see it until you remove it. And nobody will care anyhow.
    If that's not to your liking, buy some 'L' brackets at the hardware store and mount them inside the dash. Use some 1/8 sticky foam tape and attach it to the part of the L bracket that the Mini will rest on. Find something above the Mini in the dash that you can do the same with and build it up until you get a nice friction fit.
    Want to:
    Nov 2007
    Wouldn't I have to make the Mini a half inch thicker somehow before I can drill into it? If I get 1/4" aluminum sheets that are 6.5"x2" and drill screw holes into those, could I just bolt those into the side of the Mini? At the very least, I'm going to need two 1/4" spacers and longer screws... and something to put over the front of the Mini so the spacers are not visible from the outside. Otherwise, the brackets would be too close together and unable to be mounted where they need to go, considering the Mini is 6.5" square and a DIN opening is 7" long.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Installing Mac Mini in My 05 Alti SER
    By Vitulla in forum Newbie
    Last Post: 05-24-2007, 12:55 AM
  3. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
  4. New P4 system which fit into the single din slot
    By synchron in forum Classified Archive
    Last Post: 07-20-2004, 10:29 AM
  5. 6.8 inch in dash LCD. Single DIN slot
    By Cyberphox in forum Classified Archive
    Last Post: 09-17-2001, 08:26 AM
