Results 1 to 10 of 11
Thread: Sound Product Question
    Sep 2008
    hey,
    I am about to decide what to do for sound. I dont know much about the sound cards but have heard good things about this product.
    http://www.sonicelectronix.com/item_...N+MODEL+-.html
    Will it do the same as a sound card? It is blue tooth capable so I will be able to make adjustments on my mac.
    Any input is greatly appreciated.
    Elsewhere
    It is a good product, but it is not a sound card. This unit produces no audio signal whatsoever.
    The 3Sixty units are audio processors. You can tune the audio from a bluetooth-enabled PDA (or possibly a PC), but that's all. It will not allow you to adjust your Mac from the 3Sixty.
    How about the Wiki?
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    rockford are excellent amplifiers, i use the older rockford fosage in my 07 tundra with the factory speakers and nothing sounds like it.
    however if you dont have a sound card already installed on your PC either onboard, PCI or USB then this and any other amplifier would serve as a heavy brick of metal.
    i use my rockford with an onboard realtek ac 97 and the soundis crisp and clean. so if you already have an onboard or other sound card, go ahead and get this AMP, otherwise you are looking up the wrong product.
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
    Sep 2009
    As previously said, that is not a sound card. It is a sound processor. It essentially takes an RCA output, & changes it to +/- outputs for OEM integration. Then, it allows you to process the music how you want it.
    Sep 2008
    I might be misunderstanding you but the product I linked to above is not an amplifier.
    This product is not just for OEM integration, it is for aftermarket as well. But yes, it is just a eq
    Quote Originally Posted by DarquePervert View Post
    Correct, I understand it creates no audio signal but I have an after market amplifier that it will be hooked up (Sorry, should have mentioned that). With that said, with the 3sixty.2 + external amp will a sound card be needed or serve any purpose?
    Elsewhere
    Well, you need some device to generate an audio signal.
    A PC's sound hardware (either external sound card or onboard audio chipset).
    An iPod.
    A portable CD Player
    Hell, an old 8-track tape player could be your audio source.
    Yes, you have to have an audio source.
    Now, does that mean you need an external sound card in your PC? No.
    Could an external sound card improve your audio quality? Possibly.
    How about the Wiki?
    Sep 2008
    Thanks for the response.
    Now you are saying I have an " audio source" - that would be my mac right?
    And you are saying I need and audio signal. Isn't my my mac producing an audio signal too?
    Sorry if I am a little slow, thanks for the patience.
    Jan 2008
    darque is giving you different examples of different audio sources..
    it is a little confusing, but i think that you understand that the three sixty is just a eq, and that you would still need a source(pc) and a amp(you said you had already).
    Sep 2008
    right, ok now that I read it again I understand a little better. BUT back to my original question will the sound card (whether on board or external) matter if I have the 3sixty and amp?
    Elsewhere
    Quote Originally Posted by nastra622 View Post
    Yes.
    Yes, your Mac produces an audio signal. That audio signal typically is output through a 3.5mm audio jack (a.k.a. headphone jack).
    Maybe this will help: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
    Different audio hardware processes audio differently. IF you're a hardcore audiophile, the onboard audio capabilities of your Mac may be painful to your ears. In that case, then you may want higher-end audio hardware for the Mac.
    Really, though, for most people, onboard sound is sufficient.
    How about the Wiki?
  1. Unexplained sound problem
    By lexdiamond20 in forum Newbie
    Last Post: 07-10-2007, 09:30 PM
  2. 8" Lilliput question, extracting sound and screen rolls
    By clean customs in forum LCD/Display
    Last Post: 06-30-2005, 11:10 PM
  3. Sound Question
    By arkadiyp in forum Newbie
    Last Post: 04-01-2004, 04:52 PM
  4. digital sound question
    By amrit50 in forum General Hardware Discussion
    Last Post: 02-19-2004, 12:54 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
