http://www.bybyte.com/lcd_combos.html
This is the site I went to for the LCD Combo. Thing is, this sells the 7" screen. Just follow the pull down menu.
http://bybyte.com/images/99-7505+LCD_b.jpg
This is the combo you probably might end up with should you go this route.
If you use the dash that you bought from Crutchfield, be prepared to do some body work on it; it just might fit the 8" screen...
Bodywork in this instance would be expanding the inside dimensions to fit an 8" screen; with a viewing size of 6 7/8 x 4 1/8; and an exterior body size of 8.17"x5.71"x1.23".
