Results 1 to 8 of 8
Thread: Mac Mini - Amp connection
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    I looked thru this site over and over, and didn't come across anything like it...
    I began setting up my Mac to Amp connection, and with all these 20ft cable running around my Camry, I am no longer a big fan of the setup recommended. I drafted a slight modification, wanted to hear from the guys in the MacCar community to see if this makes sense:
    Any thoughts? Could this work?!
    All help is greatly appreciated!
    Sep 2005
    Auckland, NZ
    I tried connecting it the way you described and found that I had to turn the gains on amp way high which meant that the output from my mac mini (intel july 2009) was not putting out high volts. Currently I'm feeding my mac mini's stereo output into a Kicker KQ9 equaliser/crossover which inturn goes into my amps. My gains are set to minimum and the sound quality is amazing. Hope it helps.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I've heard that you can use a line amplifier to boost the output voltage to get around this problem. That said, the way you are connecting it is how I have mine connected and it seems to work just fine.
    Want to:
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    IMO it looks good. In my setup I got it plugged in a Auxiliary device that goes inside my OEM Stereo, but I my sound volume is very low even at MAX. Any idea how to boost the volume with a software or hardware???
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Jan 2008
    Quote Originally Posted by VmtSquad View Post
    most software options don't do to good- they only increase distortion, and loose clarity. you will need a line amp between the computer output, and the factory stereo input.
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    Quote Originally Posted by soundman98 View Post
    yes please steer clear of any software solutions. It will destroy your sound. Your best bet is to have the mini's audio as flat as possible (no EQ turned on anywhere in software) and then use some sort of amp/crossover/eq hardware setup to tune your sound for your vehicle.
    Check out the new version of NAS, a cross platform music frontend here
    Aug 2009
    Houston, TX
    Excellent thread. I hadn't come onto this problem but wondered. I'll be testing the diagram you have above as well. I'll let you know how it goes.
    FYI, if you install a mid line amp, you will want it as CLOSE to the Mac Mini's output as possible. This prevents the sound from being degraded by splitting the signal twice before it gets to your amp.
    Aug 2009
    BK, NY
    Okay guys, here's the update: I modded this install that instead of the y-adapter & RCA cable, I got the right angle 6ft y-cable from Radio Shack. With gains from both front and rear set at 7 (out of possible 11 or 13), the sound is amazing! Now, the only kicker is that I get only rear sound (probably a speaker cable issue), but nonetheless, it is a cool setup.
    @ Mentor: I did not use the EQ/crossover because of cash reasons. But I'm satisfied overall with the sound.
    @ Bugbyte: Do you use the line-amp in conjunction with the amp for the speakers?
    Thanks for all the input guys.
  1. Completed: 2008 Honda Ridgeline Mac Mini carputer
    By crimsonaudio in forum Show off your project
    Last Post: 01-22-2010, 04:51 PM
  2. Replies: 6
    Last Post: 07-31-2009, 12:47 PM
  3. Alpine IVA-D310 + MAC MINI
    By adammc in forum MacCar
    Last Post: 12-14-2008, 01:53 PM
  4. FS: Mac Mini CarPC Package/Parts LOADED!
    By markcc01 in forum Classified Archive
    Last Post: 01-03-2006, 11:47 PM
  5. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 01:25 PM
