Results 1 to 7 of 7
Thread: New Update breaks Bluetooth
    Low Bitrate pulsarsimon's Avatar
    Nov 2009
    Melbourne Australia
    Hi All,
    first "general" Mac post for me.
    I have a Mac Mini PPC Leopard 10.5.8 which I'm setting up for car use. Just installing + Testing front ends at the moment to get the interface right before I do the install.
    I recently decided to allow some updates from apple, one of which was called 2009-006 Security update.
    Long story short, since the update; if I have my BT keyboard connected, the MAC won't shut down. Sleep is OK. If I connect a USB keyboard it's ok too - just not the BT one.
    Found only one other forum mentioning this, and since not many people have said anything, thought I'd put it here as a head's up for others. One of the 'patches' in the update is a bluetooth keyboard "security" patch which "Prevents elevated access to Bluetooth keyboard firmware update".
    MacMini in an Alfa? - Why not!
    Variable Bitrate VmtSquad's Avatar
    May 2007
    Montréal, Quebec, Canada
    That's strange, I'll have to test this and I'll get back to ya....
    Q: Which BT KBoard are you using, Mac KBoard?
    VmtSquad - I sold my soul to Honda!
    Final Install
    CarPC progress: 95%
    Nov 2009
    Melbourne Australia
    Logitech diNovo Mini
    works fine as a keyboard/mouse.
    I see on the apple forums, there's a few people with similar problems with the Mac magic mouse -but that's connection related, not shutdown..
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    I did that same update, and bluetooth broke; a couple reboots fixed it for me. For some reason, the bluetooth icon on the top bar had a bolt through it and wouldn't turn on, but it's working again now.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Variable Bitrate natedawgg's Avatar
    Jan 2007
    Dallas
    i have a late 2006 macbookpro and a early 08 macbookpro, both of which i have run the update on. My older mbp gets the bluetooth-bolt logo while my newer one does not. The problem though is that my older one will periodically have this happen and then after reboot it goes away. im not exactly sure that it was the update that did it.
    Check out the new version of NAS, a cross platform music frontend here
    Mar 2009
    Los Angeles
    Yeah, this is an early-ish MBP. [it's the first 15.4" they released after they moved to dual-core chips with virtualisation extensions - so, "second gen" maybe?].
    Gary (-;
    Nov 2009
    Melbourne Australia
    I did some further investigation.. If I turn off the BT before shutting down, then it's all ok.
    then I have to manually turn on the BT again once restarted
    a bit annoying, but a workaround I think. might have to write a script that does this each time, unless Apple come up with a better solution.
  1. Preliminary iPhone support, Calling and Music over Bluetooth
    By dc2bar in forum Software & Software Development
    Last Post: 09-22-2008, 07:31 PM
  2. Bluetooth Serial Port Nightmare, IOGEAR, Zoom
    By matt621 in forum General Hardware Discussion
    Last Post: 07-05-2008, 08:55 PM
  3. bluetooth dongle problem
    By toofresh in forum Wireless Communications
    Last Post: 01-02-2008, 11:43 AM
  4. Centrafuse 1.14 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-01-2007, 11:34 AM
  5. 18 mile (10KM) range Bluetooth device...
    By rijndael in forum Wireless Communications
    Last Post: 07-05-2007, 03:54 AM
