Results 1 to 7 of 7
Thread: Carnetix P2140 starting mac mini
    Apr 2007
    Hello all
    Today i got around to installing my mac mini car computer with P2140 PSU/controller
    When i tested it with a powersupply a few weeks ago everything was working as it should
    now when i turn on the ignition, the p2140 powers up and starts flashing but it never triggers the mini, i can manually short the pins on the switch cable and it will start no problems
    any ideas why it would not be automatically starting?
    thanks
    Luke
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Most likely, you don't have the power supply wired properly. Check your connections.
    Apr 2007
    Power supply is wired pos to pos, ground to ground and yellow to acc
    connection from power supply is via mac pac prewired cable
    Jun 2007
    You'll probably want to hook the 2140 up a computer via USB and see what it's doing with the PSUmoni software.
    Aug 2009
    Houston, TX
    Check out this video to see if it helps
    http://www.carnetix.com/P2140/Led-sequence-normal.wmv
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    The 2140 can sometimes get 'scrambled' -especially during testing or if your battery goes dead. Hook it up to the USB and reflash it. That may do the trick.
    Want to:
    Apr 2007
    It appears it was a broken green acpi wire on the 'quality' mac pac cable
    soldered it back on the plug and that problem is now solved
    Now i have an issue of that it is sleeping my mini fine but then after around 1 minute its cutting power to it
    software is set to sleep mode
  1. FAQ: Installing a Mac Mini in Your Car
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-11-2011, 08:12 PM
  2. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 04:25 PM
  3. Mac Mini in a Mazda Protege
    By zapwizard in forum Show off your project
    Last Post: 08-07-2006, 08:18 AM
  4. Hot Rod Company to start incorporating Mac Minis
    By stacheldraht in forum MacCar
    Last Post: 02-01-2005, 12:25 PM
