Results 1 to 10 of 15
Thread: 800x600 Xenarc...squished on wake
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    So, why does this happen every once in awhile:
    When I bring the computer back from sleep, or turn it on, or whatever...it gets a signal and turns on with the image on the screen normal...then it says PC then 800x600 and the screen squishes either to the left or right so that a good 1/3 of the screen is blank.
    Odd thing is that the touchscreen works just as if the screen wasnt squished. Pushing the bottom left corner (even when part of the 1/3 empty space) activates the button in the bottom corner for example.
    Makes sense...and yet it doesnt.
    Sometimes bringing the computer to sleep and waking again will fix this issue. But its kind of annoying.
    (0.0%-) starting over
    iPad 3G 64GB, RF 600.5 amp, JL10W0V2, 8 Infinity Components
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    xport has a feature called "VGA SYNC" use that, it will fix it
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    I have the same issue, I've found that coming up with a fresh boot rather than hibernation fixes it... I'm curious what xport does to fix this so I can have the fix without having to run xport. Anyone have any clue?
    Is xport available for mac?
    RevFE
    My Shop
    Apr 2006
    Greece
    use a command line to change the resolution to 1024x768 on startup and then change it back to 800x600 5 seconds later..
    google you will find command lines to do that
    Aug 2004
    Floreeda
    I dont see how that helps when coming back from sleep at all.
    Apr 2006
    Greece
    did u try it?
    Aug 2004
    Floreeda
    You want me to run a command line when the computer wakes from sleep...as in run an applescript terminal command (you are aware this is for OSX, might matter?) that is set to run for on wake and startup (ive no clue how to do that)
    Oct 2006
    download the latest xport, an enable the video sync function. Most likely will fix your problem.
    Apr 2006
    Greece
    try this
    when the problem appears..go into OSX settings and change the resolution back and forth and see if that fixes it..
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Try XPort
    It shuts off the video output for a very short period causing the monitor to synchronize again. See if there's a way to do it in Mac OSX.
    Possibly this or the power button on the monitor.
  1. Poor audio quality Xenarc MDT-X7000?
    By jconfidence in forum General Hardware Discussion
    Last Post: 08-10-2008, 11:53 PM
  2. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 09:53 AM
  3. XENARC 700 IDT Review and ...and I need help
    By hondamac in forum LCD/Display
    Last Post: 09-26-2007, 06:39 PM
  4. Replies: 88
    Last Post: 09-15-2004, 05:38 PM
  5. "Stretched" 800x600 MediaCar F-CNS skin available
    By febsperanza in forum MediaCar
    Last Post: 06-08-2004, 12:56 AM
