Results 1 to 10 of 11
Thread: Soda! Spill!! Help!!!
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    I'm freaking out here; I'm pretty sure this question has been answered somewhere; but I'll post it anyway.
    I was showing off my MACry in Paramus, NJ. I was en route home from the mall, when the unthinkable happened...
    Soda spilled near the mini!
    The mini reacted, then deactivated itself.
    After flying off Rte 4, I disassembled my car's main dash as fast as I could. Realizing that I need to take my time with unit itself, I then focused my attention on driving home (luckily, I knew how I got there in the first place!!)
    It's so funny: when my PowerBook G4 wasn't functioning due to hard drive failure, my MACry was my main computer. Now, the tables turned. In any case, I just got finished removing the mini and disassembling it down to the drives. Right now, it's upside down in my attempts to drain any more fluids that remain. Thing is, it doesn't look like any got there in the first place.
    The million dollar questions:
    Is there a way to clean it off!?
    Am I wasting time? Should I just prepare to shell out more cash for a replacement?
    Has this actually happened to anyone?!
    No, the last one doesn't need an answer.
    I just hope that my mini isn't... dead.
    FYI: The amp is fine. I connected it to my iPhone, and music is still playing.
    The screen is fine. It just says "No Input" and turns itself off/Standby.
    The regulator "should" be fine. Since all the other components are working.
    Thanks guys!
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Might give it a go cleaning with some contact cleaner. It's basically rubbing alcohol in an aerosol can. I've used that to clean smoke/fire/water damaged PCs in the past.
    Tidder
    Try RevFE
    Jun 2008
    Perth, Western Australia
    First things first, pull it apart as much as you can, and inspect it for droplets of liquid.
    If there are any there, you have to get it off. The acid in the drink will corrode any traces very easily. Start out using a lint free cloth that is dampened in distilled water. Wipe lightly, until you have gotten any bits off.
    Then, give the whole system a good dry out. If you can split it down into smallish parts, then its a lot easier, and more likely to get all the last of the liquid out.
    But make sure that unit is dry before you power it up. If it means giving it 3 or 4 days without using it, then do it.
    Some people will also suggest using one of the contact cleaning sprays that you get from electronics stores for when you are working with circuit boards. They can be good, but just be very sparing when you use it, make sure it doesnt damage any of the plastic.
    But personally, I would go with option one, pull it apart, wipe it clean, then airdry it.
    And yeh, it happens, usually the short will just trip out the power supply and the unit is quite often okay.
    Sorry it happened dude, hope that it works out okay for you, its heartbreaking when something like this happens to your hard work.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Contact cleaner is a good way to do it. If you have distilled water, completely disassemble, rinse components (not hard drive) use the contact cleaner, then completely dry before use.
    Google up "spilled soda in computer" to see what experts suggest.
    Want to:
    Aug 2009
    BK, NY
    Update:
    Disassembly complete. Connected the hard drive to my laptop (which I'm currently using); and the hard drive is working.
    Good news...
    The Worklog
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    I would recomend a spray from 3M that can prevent damage to mainboards and such. Can't remember the correct name, but search for "waterproof spray 3m" on google should find it for you.
    Jan 2008
    get a large air tight container place rice in the bottom of it, place the mother board on some spacers so the rice is not touching the board, then seal the container and place in the airing cupboard for about a week this will allow it to draw all the out of the board, also use a solvant cleaner on it around the area that has soda on it, this will clean it away.
    http://www.rapidonline.com/sku/Tools.../61602/87-1164
    MOST IMPOINTANTLY - DONT TURN IT ON.
    Low Bitrate SoloconDeus's Avatar
    Sep 2007
    OK from experience, I spilled about half a can of BAWLS on my wife's laptop.
    I turned it off and took everything out. Including the processor. I Then grabbed a can of denatured alcohol , there is not water in it. (Lowe's or Home Depot) I then poured it in a large cooking pan, then I placed the mobo, processor and memory in it over night. I gave it the occasional firm shake.
    I pulled it out the next morning, looked at it for traces of BAWLS, cleaned those with a Q-Tip and the Alcohol. Put it all back together and it is all still working 5 years later =).
    My new install
    D945GCLF2, M350 case,Xenarc 700 tsv,m-4 ATX
    Visteon HD radio w/mitches cable, BU-353
    2 Punch 150 amps, 1 Kicker ZX 400.1 watt
    4 Boston Acoustic Speakers,2 Pioneer 10 subs
    Aug 2009
    BK, NY
    Ok, guys. I have news!!
    After days of no response from the mini, I poured alcohol in a pan, and basically left the logic board in the pan with the alcohol for an hour or so. I took it out and let it dry. I turned it on next day, nothing. Two nights ago, my brother started moving around my stuff, including the mini. While I'm watching Shat on RAW, my brother turned on the mini!!
    To prove it was not a fluke, we unplugged the mini, plugged it back in, and it turned on again!
    I'll put it through some tests, put back the 500GB HD, run my last tests, and put it back in the MACry!!
    I'm feeling quite good. Very good. Awesome!
    The Worklog
    Sep 2007
    Cool I am happy for you. Now all you have to do is figure out what you did that worked. Btw what type of alcohol did you use?
    My new install
  1. Car Upholstery - Gas Spill
    By Ashlawn Kemling in forum Off Topic
    Last Post: 11-02-2003, 07:35 PM
