Results 1 to 10 of 10
Thread: Mac Mini Mounting Solutions?
    Dec 2007
    So my screen is in my dash the hard part is done but what is the best way to mount my mac mini. I dont have any room in the car so it will have to be in the trunk.
    so far I have found two options the MacCuff and the CinnaMount
    The CinnaMount seems reasonable for $35CAD vs the MacCuff for $60USD but they are sold out so how do you mount your mini?
    Mod - all of it. SapporoGuy's Avatar
    Aug 2009
    SonyLand
    Wow, those are pretty sweet. I like the MacCuff drawer like thingy!
    Years ago, I made a ghetto amp rack for my car. Cost me like $4. A piece of wood, 4 brackets that I bent and some screws. Looked like crap but it stuck to the bottom of my back deck and never failed me
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    You can always build your own mount. A little plexiglass and epoxy will do you.
    Constant Bitrate Kalenth's Avatar
    Aug 2006
    DFW
    What kind of car? There is typically a lot of room behind the dash if you know where to look... and don't mind a little modding. And who here doesn't mind a little modding!?
    Dec 2007
    Quote Originally Posted by Kalenth View Post
    1998 nissan 240sx I could probably fit it behind the screen but I prefer the trunk
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    Im using a cinnamount in my center console:
    holds it tight and still able to slide it out if I needs to.
    adhesive foam tape holds it to the side of the center console.
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    Jun 2007
    sdashiki, how do you have your wires rigged up?
    I have mine under the center console with a hole in the bottom to connect to the Mini. It's kind of a pain to disconnect and reconnect the Mini because I can't see what I'm doing. Longer cables would probably help. Or some sort of docking solution like what BugByte did.
    Aug 2004
    Floreeda
    Ive got long enough cables to pull it out. They run into the cavity underneath the center console, there is surprisingly alot of room. The mac is inside the center console compartment, but the wires and everything run inside the console itself towards the dash.
    However, I put the P2140 inside the console itself two (outside the frame to the left underneath the cup holders) and this is causing heat issues. So I have to move it where there's more air circulating.
    (All done)
    Jul 2010
    Dublin, OH
    I plan on fabbing up a simple bracket with some rubber mounting points to help soak up some of the vibrations.
    Those links you provided are pretty neat. Maybe I'll just buy one of those lol
    Constant Bitrate scatebase's Avatar
    Oct 2008
    I used a mount from "H-Squared". It has held the mini for over 2 years without any problems.
    http://h-sq.com/products/minimount/index.html
  1. Mini Mac 4 Porsche 944
    By 4thChild in forum MacCar
    Last Post: 03-13-2009, 11:16 PM
  2. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  3. A Great Idea for the Mac Mini In the car
    By ametalix in forum MacCar
    Last Post: 07-13-2007, 01:11 AM
  4. Mac-centric links
    By kandyman676 in forum MacCar
    Last Post: 04-16-2007, 11:46 PM
  5. First Mac Mini in a Land Rover
    By dmonckton in forum Show off your project
    Last Post: 08-14-2005, 07:53 PM
