Results 1 to 8 of 8
Thread: I can't seem to get a straight answer...
    Mar 2011
    On a Mac Mini(older), there are three wires to the power cord. The ground(-)blk, +18.5v red, and now the sixty-four dollar question. What does the white wire do? How do I hook it up? I'm going to use a laptop car adapter for power. Your assistance please.
    Raw Wave
    Nov 2009
    Strange....
    I have no idea.
    But I use google and find the answer pretty quick.
    Amazingly enough, the best is probably on this forum from use johnsin on a thread to do a P1900 and something called a Mac Mini.
    This may not be a straight answer, but is should enable straighter answers for you in the future...
    Mar 2011
    What's so strange about that? You don't seem to have a clue. Most of what you wrote was incoherent. I don't even know what you said!??
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    First up, welcome to the MacCar Forum!
    Second, I notice through your prior posts that you are avoiding using the CarNetix regulators and are going forward with using a car adapter instead. If that's true, this link might also be of help, as well as this link.
    I am interested in possibly having this option as a backup, so please do tell us if you were successful, and what you did (or should have done) differently.
    Third, the white wire is 9/10 the iSense wire. Supposedly, it makes sure that the right power supply is used to power the Mac Mini. It works by putting an amount of resistance on the ground. It senses this resistance and tells the Mac if it is safe to turn on or not.
    Best of luck!
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
    Mar 2011
    Thank you. You've been quite helpful. I'll let you know how it goes.
    Aug 2009
    BK, NY
    No prob. By the way, OldSpark was spot on about his answer. This is the info he was speaking of. This was done before, but I believe on a PPC Mac Mini. If the principle runs the same, then you should have little problems...
    The Worklog
    Raw Wave
    Nov 2009
    Quote Originally Posted by Bob91403 View Post
    In summary: SEARCH!!!!!
    ---------- Post added at 03:03 PM ---------- Previous post was at 03:01 PM ----------
    And thanks to Project07MACry.
    I went from knowing NOTHING to being spot on in what - 4 minutes? Less time than this thread?
    That's the trouble with old people - they can't find anything on the net - they just ain't savvy enough.
    Mar 2011
    First, I'd like to apologize if I offended anyone with my ignorance. I'm new to this. I did my build, it worked fine for about eight hours, then started rebooting over and over again, every five seconds. I unplugged it, checked the voltages, everything seemed okay. An hour later, same thing. I get the feeling that the 3.3K 1/2w resistor is overheating and failing. I don't know how to check it, or what to look for. Please, someone, help me out. I'll share my $20 build here, as soon as it's finished. Thanks
  1. Straight Talk
    By Dak446 in forum In Vehicle Phone Integration
    Last Post: 01-29-2010, 01:22 AM
  2. Ok so let me get this straight...
    By JpLelko in forum Newbie
    Last Post: 11-10-2006, 09:36 PM
  3. App goes straight to toolbar
    By thanatos106 in forum SkinBedder
    Last Post: 08-19-2006, 02:13 AM
  4. Who is using their carputer straight to an amp?
    By verbal kent in forum Car Audio
    Last Post: 02-11-2006, 10:30 PM
  5. Replies: 12
    Last Post: 02-01-2005, 10:25 AM
