Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Apple Tv in car Project started
    Jun 2011
    Cool Apple Tv in car Project started
    I have purchased (a certain bit site) an Apple Tv1 for my car (I have one at home and use it all the time with about 12,000 songs on it synced from iTunes and a great deal of them are wav files so large storage needed).
    I have got a unit with a 640GB hard drive inside(sata) for the extra storage.
    I have tonight removed the Apple internal power supply and connected it to an external 10 amp 5 volt regulator and has now been running for 4 hours no problem the heat sink on the external power regulator isn't even warm, current in amps tested at 1.05 amps to max of 1.5 amps at 12volts (suggested 7.5 amps elsewhere on the net.
    I am going to leave it running all the time so i can sync it when its parked via wifi and also for quick start up time, the voltage regulator has a shut of so if the battery gets too low it will shut of leaving enough to start (hopefully, also a main kill switch for long parking).
    I plan to run a wireless router in the car (12 volt regulated and ignition acc switched) with a connection to Ethernet port on the Apple Tv so I can wifi my iphone using remote Hd (also remote HD installed on Apple Tv) then when the engine is switched off and key out the Apple tv switch's to Wifi mode (tested) which then links to my home Wifi signal for syncing to itunes.
Size:  33.3 KBName:  IMG_2013.jpg
Size:  26.2 KBName:  IMG_2028.jpg
Size:  36.1 KBName:  IMG_1997.jpg
    Jun 2011
    OK Sorted out Composite video output (normal yellow video lead output) as this unit does not have one, only HDMI and component (red blue Green plugs) so it will need standard video to run in standard car screens.
    To get apple tv to work with Composite video plug in your video lead to the green phono output on the back,
    2 ways to do this
    1- flash tv and then install nito tv and composite video plugin.
    Assuming you have nitoTV installed properly and 480i selected.
    - go to nitoTV - Settings - Utilities - Kernel Extension Manager - TVComposite.kext - press the Play button -> you should see color immediately
    To add it to startup, press the Fast Fwd button and then Create Startup Item
    (Thanks atvnoob from hackint0sh org for that tip)
    2-The other way if you don't have flash installed is an HDMI converter and another converter for this way I would google it as i did not use that route
    Trying in the car later today (hopefully if kids and my wife don't side track me)
    Jun 2011
    Tested in the car and works well.
    I had to run the wireless router on a mains inverter to test it but a 12 volt, 1 amp regulator should sort that problem out.
    All controlled by the iphone (as connected to same network router) with the Remote App (the Apple one, grey outer and blue with a black play button)
    Also the Remote HD App works well for seeing the whole screen output if you need to tweak it.
    The car monitor also works although in NTSC but still in colour and plays movies ok for the car.
    All in all well happy, now to wire it in properly.
    Pics soon.
    AMP Creator aychamo's Avatar
    Jun 2006
    Wow! I didn't even know Remote HD app existed!
    This looks like a really neat project. Please keep us updated and post some pics!
    Jun 2011
    Ready for installation in to the car, soldered and heat shrinked and i used an EC3 plug (60amp r/c car battery connector) for easy removal
    And very temporary install in the glove box for testing with wireless router connected by cat 5.
    Jun 2011
    Also i took the car for an hour journey each way and worked very well.
    Very pleased to be able to access my 12500 songs in the car.
    I will keep you informed.
    More pictures soon.
    Jun 2011
    This guy has done some interesting stuff with the apple tv in the car
    http://brandon-holland.com/
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    Awesome work!
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
    Feb 2002
    From this idea, I went and found an apple tv 2, which uses a whole lot less power and started the adaptation. I should have it installed soon, just put a power plug into it to connect to a DC-DC 3.4 v power source From my testing it looks like I'll be able to hop into my car, open the remote app and control the itunes, or stream from my iphone / ipad, or a NAS device, lots of ideas in my head right now that I'm trying to sort into a perfect combination.
    I guess I'll need to put a real wifi router in the car, I was hoping to use the MyWi access point in my phone, which gives the car computers internet access, but airplay doesn't seem to work over it. Anyone try this setup before? Can I bridge the internet connection from MyWi / iphone into the router, and have it feed all the computers? Are there any low power consumption / tiny routers that I can DD-WRT?
    Old School MP3CAR.com member!
    Maximum Bitrate pepsibobby's Avatar
    Dec 2005
    Kaiserslautern Germany
    dont forget that the Apple TV 2 is also hackable. it doesnt do much yet, but you can add some content.
    Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
  1. My project has started: all in one for VW T4
    By T4Roger in forum Worklogs
    Last Post: 01-12-2008, 04:30 PM
  2. New Project Started
    By Difinity in forum Worklogs
    Last Post: 09-26-2006, 07:21 PM
  3. Replies: 10
    Last Post: 03-24-2006, 03:25 AM
  4. Mac mini project started...
    By GSoup in forum MacCar
    Last Post: 01-27-2006, 09:54 AM
  5. My Project (just started)
    By UncoCow in forum Show off your project
    Last Post: 02-07-2003, 06:41 PM
